Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I use the MN-700 and have talked to the customer support
guys in India for 3 days trying to resolve my issue:
I switched to the WPA encryption on the wireless router,
since then I will connect but after several minutes the
internet connection is no longer available, but the
computer is still connected, with good signal strength, to
the router. If I reboot the computer, nothing changes.
The only way to fix the problem is to go into the network
managment page and reset the router. After a reset the
wireless laptop is able to connect again. However, after
several minutes, the problem begins again. I did not have
this problem using WEP encryption, so it appears to be
isolated to the new level of encryption. How can I resolve
this problem?
this problem?
