I have a PC upstairs that's far away from my router downstairs, the signal is weak and I saw a good deal on Newegg for the TP-PA211 powerline adapters so I decided to try them. I was planning on running the powerline adapter's output to a Trendnet 8-port Gigabit GREENnet Switch. Then I would plug my PC, laptop, and Xbox into the switch.
Also, my the Ethernet port on my motherboard worked fine until about a week ago when I used it occasionally to try and stream content over an Ethernet cord to my Xbox. One day, I couldn't get a connection using it and I checked device manager on the computer. I saw under "Other Devices" "Ethernet Controller" was listed with a yellow exclamation point. I tried to update the drivers and after that didn't work I bought a new PCI-E networking adapter:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833106033
I just installed it and updated the drivers and connected the Xbox and PC together through the switch. I tested the PC connection and it failed. So I unplugged the switch and plugged the PC directly into the Xbox. It's still failing the PC connection test with an "IP Address Error".
So what's wrong with this connection and how can I fix it? I would like to run it through the switch because my PC only has one Ethernet port, but getting it working with a direct connection would be a good start.
Here is the problem I'm having with the powerline adapter. The powerline adapter utility usually finds the other device, but it will lose it every few minutes and say "HomePlug is not detected"
Also, when I click on Device 2 in this picture and click Add or Enter Password I type in the password that is written on this device and get this error telling me the password is wrong:
How can I set this adapter up properly? I followed the little bit of support available online and nothing has changed.
