I'm hoping some of the veterans could chime in here.
When getting ready to use a condenser mic, this is typically what I
do:
1) make sure the preamp/mixer is off and the gain is set to zero
2) plug the condenser mic in with the xlr cable
3) turn the mixer on
4) turn phantom power on
5) wait a few seconds, then slowly bring the gain up and snap fingers
near the mic lightly and look for the meters to indicate signal
When powering down:
1) turn gain to zero, turn phantom off
2) wait a few seconds, then turn mixer off
3) wait about two minutes, then unplug the mic from the xlr cable
Am I being too careful here? Particularly with power-down, I like to
wait about 2 minutes after phantom is off to unplug the mic (so that
there is no residual power which could "shock" the mic and damage it).
In article <6c38b64b.0408202329.340ca91b@posting.google.com> genericaudioperson@hotmail.com writes:
> do:
> When powering down:
A little, but extra care certainly doesn't hurt. It's a pretty good
idea to have phantom power off and gain down (at least monitor gain)
when plugging in a mic (which includes the cable and both its ends).
Turning the gain down before turning off either phantom power or
unplugging a mic is a good idea. But to avoid unexpected pops in the
speakers you should turn the power amplifier off before you turn off
the mixer. This is probably a good reason not to turn off the mixer
ever time you plug or unplug a mic unless you're closing up shop.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
