Tom's Hardware > Forum > Mobility Brands > Motorola > v60 antenna replacement
Archived from groups: alt.cellular.motorola (More info?)
The stub antenna on my v60g (T-Mobile) phone broke again! This is about the
3rd time it happened. I don't even know how--I just noticed it is off, and I
can't place any calls!
They seem to be pretty chintzy, and break off easily. Is that also true with
the newer Moto models-v600, etc.?
Anyhow, I saw on www.cellularoutlet.com replacement stub antennas for $5.99.
They also had a retractable antenna for this phone for the same price. (No
shipping charge either. Just tax here in CA.)
Would the retractable antenna be less likely to break off? Would extending
it get better reception?
How easy is it to replace the antenna? What tools are needed? What is the
procedure?
Thank you in advance to anyone who helps. :-)
Sponsored Links
I suggest using this website for ordering any stuff. I have ordered several
times and never had a problem.
http://www.cellphoneshop.net/v60.html
" MS" <ms@nospam.com> wrote in message
news:1084672845.852380@news-1.nethere.net...
the
I
with
$5.99.
> procedure?
Reply to Anonymous
- 0 +
That wasn't my question. I didn't ask where to buy one. (In fact, I have
already ordered an antenna, through cellularoutlet.) I asked how to replace
the antenna.
"Reverend Dalton" <Dalton_Michaels@hotmail.com> wrote in message
news:UZQpc.474608$Pk3.199133@pd7tw1no...
several
> the
and
> I
> with
> $5.99.
(No
extending
the
> > procedure?
Reply to ms
The retractable antenna is probably more likely to break. It does appear,
however, to be much easier to replace when it does break - requiring only
a flat-head screwdriver.
I live in a fringe area. I'd say I get a good half bar increase in
strength when it's extended, meaning the difference between no signal and
signal for me.
Cheers,
Tim
Reply to Anonymous
Good luck installing a new antenna in that thing. The one I had snapped
off, and there are no threads to speak of for installation of a new one.
It's seems the antenna was built as a part of the phone. I have seen
the extending antennas, and I personally think they are completely
useless. What good is and extra inch? If anyone can give me an actual
figure in how many more decibels it gives you, I will be impressed.
Actual testing too, not manufacturer specs.
Torrance
Reply to Anonymous
> Torrance
Hi Torrance,
I'm getting -105db with it extended and -110db with it not.
I sampled back and forth three times, letting the signal settle aftwards,
and took the reading which was displayed for the most time (didn't use a
stopwatch, but paid attention to it for 30 seconds on each try after
settling, rounding up on the extended and down on the not in order to
eliminate any personal bias). I tried to hold the phone in the same
position each time (roughly vertical and ear-level while sitting at a desk).
Cheers,
Tim
Reply to Tim
is that a really good improvement? How did you take the measurements?
:P I'm not real big on how much signal phones use or need, i just wonder
if it makes that much of a difference. I know most of the nokia phones
dont even have an antenna stub.
Torrance
Reply to Anonymous
- 0 +
"Torrance Bell" <starlite528@yah00.com> wrote in message
news:bDWpc.67882$DV6.44294@newssvr25.news.prodigy.com...
> Torrance
Phones that don't have an external antenna have an internal antenna. That's
better, IMO, to avoid this problem of breakage.
They do need some kind of antenna. For instance, now with the stub broken
off my v60, it's completely useless, cannot complete any call.
Reply to ms
- 0 +
news:tDUpc.93$m96.64@newssvr27.news.prodigy.com...
Well, if they are selling replacements, it seems there must be some way to
replace it. I haven't yet figured out how though.
> Torrance
Reply to ms
Hi Torrance,
It's a difference of 10 to the -10.5th power vs 10 to the -11th power.
..00000000000316228
vs
..00000000000100000
Note: I'm not a math person, take the above figures with a grain of salt.
So roughly 3 times the signal. Granted my measurements weren't
scientific - when I return from vacation I'll probably do more extensive
testing (along with a Wilson car antenna and a Wilson Yagi antenna).
I do, however, notice a near-immediate change from "No Service"
when sitting at my desk to getting digital service when I extend the
antenna - this is where I did my test.
More information on deciBels can be found at:
http://www.wordiq.com/cgi-bin/know [...] le=Decibel
Test mode: while the v60t boots, press ##. (To leave test mode, menu then
left-soft.)
Cheers,
Tim
Reply to Tim
Unfortunatly, my v60 broke a long time ago. I forgot to mention what I
was using as my antenna, here is a pic of it:
http://www.lordshadowstar.com/Phone01.gif
http://www.lordshadowstar.com/Phone02.gif
http://www.lordshadowstar.com/Phone03.gif
Torrance
Reply to Anonymous
Hi Torrance,
Now that's creative! You might try a longer screw to see if you can get
another 4dB out of it! LOL
Cheers,
Tim
Reply to Tim
A 3 db gain essentially doubles signal strength. It's logarithmic - not
linear. I had a short pull up antenna on my v60 and found that in
strong signal areas it made no difference but in weak areas it offered
one "bar" of improvement. Not a scientific study by any means but it did
help a little. Given the cost of about $2 for the antenna it's worth
experimenting with.
>> wonder
> phones dont even have an antenna stub.
> Torrance
Reply to Anonymous
There are 1137 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
