Cable outage, parts of LAN down?
I lost internet from the ISP and parts of our LAN went down.
We were able to reproduce the error.
Problem: Internet from ISP drops, program using port 10541 within the LAN stops communicating with a server.
The computer and server are on the same switch, neither require access to the internet.
How we fixed the problem, temporarily: Unplugged the power from the cable modem.
How we reproduced the problem: Unscrewed the cable drop to the modem and powered it on.
I have checked our firewalls logs and have seen nothing that stands out. I was able to ping the server from multiple computers, including the one that had the program running on it.
EDIT: More info:
Also while the internet was down, I tried removing the DNSs from the computer running the program, this made no difference.
1 answer Last reply
More about cable outage parts down
  1. Going to be tough to find I suspect. If the server and the computer are on a actual switch and are on the same subnet the traffic should go in one port and out the other and not care about anything else. What could be happening is that the application on the server is trying to talk to another machines that does go though the modem. For example asking a login server if your machine has rights to access the application. Your firewall comment makes me think your configuration may actually be more complex than both machines on a single switch.
    Best advice I can give is to load a copy of wireshark on the server and capture the traffic when it works and when it does not. You will want to carefully look at the mac addresses it is using to ensure it is not doing something strange like send the traffic to the router rather than directly to the client machines.
LAN Internet Service Providers LAN Cable Internet Networking
