Tom's Hardware Forums » CPU & Components » Sound Cards » Help! Seismic Edge not "seen" by Soltek mainboard
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Help! Seismic Edge not "seen" by Soltek mainboard
Profile: stranger
More Information
I have the Soltek SL-75DRV2 and the Philips Seismic Edge (PSC 705) sound card, but the motherboard refuses to "see" or recognize that the Seismic Edge is installed. I've tried everything from switching PCI slots, to changing settings in the BIOS, but nothing works. Anybody have this problem or know of a fix? Thanks in advance.
PS: Yes, the soundcard works perfectly fine in other mainboards I have tried.
Related Pr oduct
TWC
Profile: enthusiast
More Information
Make sure plug n play is enabled in the bios.
"I'd rather laugh with the sinners than cry with the saints."
Profile: Faithful Poster
More Information
Did you try the sound card in other computer? Maybe it is broken.
More Information
Did you try the sound card in another computer? Maybe it is broken.
Profile: stranger
More Information
Yes, I have Plug and Play enabled in the BIOS. I have also tried it in other computers with the same chipset, and it works perfectly fine.
Add a reply
Google Ads
