Closed
Connecting via Ethernet disables wireless connection
I've been trying to use my laptop (Lenovo IdeaPad Y580) as a wireless adapter for my Xbox 360 by bridging the LAN/Wireless networks and connecting the Xbox to the laptop via Ethernet. The wireless works fine normally, but when I plug the Ethernet cable into the computer, the laptop automatically disables WiFi and changes to a LAN connection. It doesn't give any options whatsoever to reconnect to wireless, just forces me to use the Ethernet connection. As soon as the cable is removed the wireless connection returns, but for what I'm trying to do to work, I need both LAN and wireless to be working simultaneously, and the wireless providing the Internet connection. I've also tried connecting the laptop to a router via Ethernet and received the same result, so I'm pretty sure it's something on the laptop that's causing it. Is there a way to change this so the laptop can use the wireless connection while plugged into another device via Ethernet? Thanks to all who respond.
6 answers Last reply
More about connecting ethernet disables wireless connection
  1. Do you have both the wireless and wired connections set to use DHCP? Are you using any third-party anti-virus/anti-malware, such as McAfee, Norton, etc.?
  2. Thanks for the reply. Yes, both connections are set to use DHCP. I'm using Microsoft Security Essentials, but I've tried disabling the antivirus software temporarily and it didn't solve the problem. As a note, I can work around not bridging the connection, but even when unbridged the LAN automatically disables WLAN, which pretty much stops me from doing anything.
  3. Hmm, seems very odd. Try booting a live Linux CD (e.g., Ubuntu) and see if you can maintain a connection to both at the same time. IOW, switch the OS and see if it makes a difference.
  4. I have a HP laptop with an Intel Wireless NIC. In my BIOS there is an option called "Wired to Wireless Switching" If that option is enabled the laptop will disable the Wireless NIC if a cable is connected to the Laptop.
    Check your BIOS settings, if you have a similar setting in there turn it off and you should be fine.
  5. The security issue gives reasons to switch from Microsoft to Linux Mint. I did this several years ago and have never looked back. Others in the household refuse to take the step. The security tools available through the Open Source software allows for incredible monitoring of the networks. And it is free .. I support these guys because they are doing a fantastic service which will in the end help solve the problem of monopolization taking place in the industry. My favorite EtherAps :!)
  6. It's probably by design. If the router has ethernet ports plug the xbox into it
LAN Wireless Laptops Connection Ethernet Card Networking
