"all storage devices still have to share the 133 Mbps bandwidth of the PCI bus."
*clears throat*
ok first of all all Intel computers have 266MBps bandwidth. MegaBytes! not Megabits! if it was 133Mbps (which says 133 MegaBits per second) it would only be 16.625MBps bandwidth! You wouldn't be able to run anything! Everything would be slow! And there would be no way in hell you would even get 30MBps harddisk drive speed let alone 16 which is the old PIO 4 standard!
WHoever wrote this article clearly has no clue the difference between MBps and Mbps. there is a HUGE difference between the two! HUGE! it's a factor of 8!
I want tomshardware to edit the article and update it and clearly mark the difference! this is misleading! newbies are gonna think that the pci bus is only 16MBps! when it's 133MBps or in todays world 266MBps. WHich is clearly fast enough to run serial ATA 150 hard drives.
Once again tomshardware releases a confusing misleading POS article!
<A HREF="http://www.anandtech.com/mysystemrig.html?id=9933" target="_new"> My Rig </A>
*clears throat*
