Not too big, not too small, nice and sturdy, great features, <A HREF="http://www.newegg.com/app/Showimage.asp?image=11-152-008-01.JPG/11-152-008-02.JPG/11-152-008-03.JPG/11-152-008-04.JPG/11-152-008-05.JPG/11-152-008-06.JPG/11-152-008-07.JPG/11-152-008-08.JPG" target="_new">Check it Out</A>
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
That's why I was considering <A HREF="http://www.newegg.com/app/Showimage.asp?image=11-150-018-01.JPG/11-150-018-02.JPG/11-150-018-03.JPG/11-150-018-04.JPG/11-150-018-05.JPG/11-150-018-06.JPG" target="_new">this one</A>
Apparently you can get them with 400W supplies these days. I figured you could mod the rear case fan grills for a second PSU. Just remove the drive holder there. I use chimney fans anyway.
The other mod I would make to this case is the hole between the bottom and top compartments. It could do with a little more spaciousness.
I got some basic cases like that! The second link I made is for <A HREF="http://www.newegg.com/app/ViewProduct.asp?submit=manufactory&catalog=281&manufactory=1524&DEPA=1&sortby=14&order=1" target="_new">This Description</A> which shows that case at $89. The main outstanding feature is its slide out drive trays, quite a deal I think for $89. Another nice feature is the 120mm fan bracket behind the CPU. And it's not as tall, so it would probably look better on a desk (with the rollers removed). It looks a lot better in black, see the company's website.
