I need network storage solution help!
This has been frustrating me for a couple months. I've originally been looking at buying a My Book Live or Goflex gigabit network drives but I'm not sure it's what I'm looking for.
I don't want an interface or setup or anything. I just want it to appear on my network as a drive like when I plug it in (either USB shareport or gigabit ethernet). I think this is normally not possible, but I have a DIR-825 D-Link router with a shareport USB spot. I can plug in a USB drive and access it through the shareport utility. This works great but I need something larger than 32GB - something in the TB's. Unfortunately I can only have 1 computer access it at a time, but that's all I really need for now.
I have 2 1TB drives that I don't use. I'm wondering if I can buy a regular (non-NAS) USB external enclosure and be able to slide the 2 drives in and then hook it up to the router via USB through the shareport. Would it be recognized as a storage drive on its own? Would it see both separate drives? I have no idea. It would be NICE if I could set the unit up manually in RAID1 mirorring, and basically show up as 1 1TB storage device from the shareport utility.
Anyone have any experience with this? Any insight would help me out a WHOLE BUNCH! :D
Thanks!
6 answers Last reply
More about network storage solution help
  1. I personally think you are making more of this than it is. Using a NAS device, it takes less than two minutes to permanently map the network drive to a driver letter on a Windows client.
    Ok great :) But will it work the same way if I want to use a 2-bay NAS and do RAID 1? Can I physically set up an enclosure this way or does it have to be configured with software first? Do I have to have the enclosure plugged into a PC to actually use RAID (I don't think so but I want to make sure)?
    Thanks for the quick reply!
  3. The NAS device just shows a drive to the clients; the clients do not know/care what the RAID is. If you want RAID, then simply get a NAS device that supports RAID. The RAID setup is internal to the NAS device, and usually you connect with a browser to the IP address of the device.
  4. Can I do the same thing with just a regular USB external enclosure that has RAID, and connect it to the shareport?
  5. If you mean the shareport on your router, then yes, I believe you can.
  6. Great, thanks for the input. I ended up just getting a D-Link DNS-325. Refurb'd was only $70! Works like a champ other than getting it setup was a pain. And apparently if I put a new drive in I'm FORCED to format it. I don't understand why I can't put in an existing data drive...
Networking
