The cable you split, was it an 80 pin or 40 pin? 80 pin cables has every second wire connected to ground in order to limit crosstalk. When you split the cable and make it round, you reintroduce the possibility for excessive crosstalk. If you at the same time have a long cable and run UDMA (fast transfers) you might get errors. Thats why I do not use round cables, since im not willing to take the risk. The best way to make a round cable, is to take an 80 pin cable and split it between the wires, BUT ONLY BETWEEN EVERY SECOND. In that way, every signal wire is still close to a ground wire. Its not as good as the original (Since here, every signal is in between two ground wires). You do change the cable impedance and increase crosstalk. But the above solution is deffinitely better than splitting a 40 pin cable, or an 80 pin cable between every wire.
