Yes No
Ads
Tom's Hardware > Forum > Home Audio > Pro Audio > 'POWER CALIBRATION ERROR"
Forum Home Audio : Pro Audio 'POWER CALIBRATION ERROR"
Archived from groups: rec.audio.pro (More info?)
I recently bought a new pc but everytime i try and write a CD using Wavelab
or even Nero i get a 'POWER CALIBRATION ERROR"
How can i fix it?
TIA
KC
"cannone" <kevin@itsmusic.co.za> wrote in message
news:41341f02.0@news1.mweb.co.za
> Wavelab or even Nero i get a 'POWER CALIBRATION ERROR"
> How can i fix it?
Clean the lens and change media brand or batch.
Reply to Anonymous
Firstly, it is a brand new Samsung writer. I took the writer back to the
supplier and they swopped it out and the same thing is happening to the new
drive. I have tried several different disks and i get the same reading.
Somebody told me that it can be sorted out with software. They said it is
just an alignment correction which must be done. Can anyone varify this?
KC
"Arny Krueger" <arnyk@hotpop.com> wrote in message
news:lMKdneqUFYxuqqncRVn-jQ@comcast.com...
> > How can i fix it?
Reply to Anonymous
news:4134594b.0@news1.mweb.co.za
Bad production run?
> the supplier and they swopped it out and the same thing is happening
> to the new drive.
Time to change brands or models?
> same reading.
Same discs from same vendor, or a variety of brands?
> done. Can anyone verify this?
There are no user mechanical adjustments on a computer optical drive.
You can update the firmware with software, and you can clean the lens, and
that is about it.
One word: Liteon.
Reply to Anonymous
In article <41341f02.0@news1.mweb.co.za> kevin@itsmusic.co.za writes:
> How can i fix it?
Use a slower writing speed. If you have a 52X speed drive, chances are
the software will defaut to that speed. Drop it to 16X and it'll
probalby work fine. Start increasing the speed and find out when it
quits working with the media you're using.
It's cheaper to burn slower than to throw away your media stock and
buy something else. But next time you need to buy disks, try a
different brand.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
I write at 4X
KC
"Mike Rivers" <mrivers@d-and-d.com> wrote in message
news:znr1093953060k@trad...
Wavelab
> > How can i fix it?
> different brand.
Reply to Anonymous
On Tue, 31 Aug 2004 15:37:43 +0200, "cannone" <kevin@itsmusic.co.za>
wrote:
>I write at 4X
Possibly too slow for today's media? I assume you're TRIED other
speeds? Same error?
CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
"Possibly the world's least impressive web site": George Perfect
Reply to Anonymous
[There was a server error when I tried to post this the first time; if
this is a duplicate message, please ignore it. --ds]
Several discs of different brands? That would be important to try.
If you try several discs from the same batch of the same make, then you
either have a bad batch or a type of disc that simply isn't compatible
with your writer. It happens--current Maxell audio blanks, for example,
are incompatible with my two Philips audio recorders, and I've had some
really bad experiences trying to use them (reported in another thread here).
No--for an ordinary end user like you or me, that is not correct.
With a specially rigged burner in the development lab of a drive
manufacturer they can probably do that, but not with a finished
product as sold to the consumer.
> They said it is just an alignment correction which must be done.
When you insert a disc that hasn't been finalized and is available for
recording, the recorder calibrates the power of the laser beam so that
the dye in the disc will be burned correctly. Dyes vary a lot. Newer
ones, for discs that can be recorded at high speeds, for example, are
quite different from older dyes which were only designed for 1x - 8x
recording speeds.
If the dye cannot be burned correctly by any available setting of the
laser beam's power, then the disc is rejected by the burner and you
get the message that you're seeing.
This calibration process is controlled by firmware in the burner, not by
any software in your computer that has settings which you could control.
If you get more than one or two calibration failures with a certain
type of blank disc, don't try to use that type of disc for anything
that matters, because you could very well lose the entire recording. I
am speaking from recent, hard experience with this exact same problem!
--best regards
recording speeds.
--best regards
Reply to Anonymous
- 0 +
"cannone" <kevin@itsmusic.co.za> wrote in message news:<4134594b.0@news1.mweb.co.za>...
> KC
> > > How can i fix it?
I don't see how it could be sorted out by software. I think the
calibration routine is probably a firmware thing in the burner and
Nero is a well known burner software so I doubt it is a programming
error. Does Nero list the samsung as compatible with Nero? Might want
to get a different brand.
Mike http://www.mmeproductions.com
Reply to Mike
In article <41347f20.0@news1.mweb.co.za> kevin@itsmusic.co.za writes:
> I write at 4X
Well, maybe that's too slow for your media then. Try a few other
settings. You can use some coasters, can't you? It's almost time for
the Labor Day party (or whatever you party for over there).
Reply to Anonymous
- 0 +
>From: mmeprod@mmeproductions.com (Mike)
Not really. It's a physical process that takes place on the disc. Near the
center of the disc is the power calibration area, which is where the burner
will "calibrate" the laser to be sure that the disc will be readable if it is
burned at the selected speed. If this test fails, you get the power
calibration area error.
and
If it wasn't compatible with Nero, you wouldn't even get as far as that error
message. You'd get some sort of "no supported drives found" error.
Might want
-John Vice
www.summertimestudios.com
Reply to john
- 0 +
>From: mrivers@d-and-d.com (Mike Rivers)
>Date: 8/31/2004 2:54 PM Eastern Daylight Time
>Message-id: <znr1093970971k@trad>
>> I write at 4X
>settings.
These are the ideas you should follow. If you've already swapped out the
drive, then chances are it's fine. 9 out of every 10 times I received this
error, changing the burn speed fixed it. I used to do a tech support for HP as
a day job, so I'm pretty well versed in these things. The best advice on this
thread so far is to try different burn speeds.
-John Vice
Reply to john
"David Satz" <DSatz@msn.com> wrote in message
> recording speeds.
Interesting post David... I just want to add, that there may be a bad run
of these Samsung drives. I added one recently to a box that was operating
with an old workhorse HP that would do no more then 2X - - the HP would
write on virtually any media, but I grew tired of it's lack of speed. (This was
on a goof-off audio editing box at home).
The Samsung IDE drive worked for about two weeks and the "Power Calibration
Error" began occurring, regardless of the media (TDK, TY, Maxxell, Kodak, etc.).
I didn't even bother with a return, I tossed it in a box after doing the normal, time
consuming things... uninstalling, removing, cleaning, cleaning up the registry,
re-installing, etc., to no avail. I could not move beyond the error message and
it wasn't worth the time & trouble to return it or examine it further.
David Morgan (MAMS)
http://www.m-a-m-s DOT com
Morgan Audio Media Service
Dallas, Texas (214) 662-9901
_______________________________________
http://www.artisan-recordingstudio.com
Reply to Anonymous
<< jsvice@aol.com (John) >>
<< Not really. It's a physical process that takes place on the disc. Near the
calibration area error. >>
I get that error on an older 2600 drive I use with Masterlist CD, and
I think because the old drive didn't like the longer track length that many new
CDR's are capable of. I figured maybe the longer CDR length puts the
calibration area in a harder to reach area for the laser. But if I reinserted
the disk after trying a speed check or something it would work after a bit, and
be a decent dupable copy. ( Masterlist CD is kinda a dinosaur though, but if
you want a copy Sam Ash Manhattan has a pile they want $50 each for! A couple
of years too late I think... )
Will Miho
NY Music & TV Audio Guy
Off the Morning Show! & sleepin' In... / Fox News
"The large print giveth and the small print taketh away..." Tom Waits
Reply to Anonymous
i tried using Wavelab and Nero and got the same result from both programs.
The copy of nero which i am using is a OEM version which came with the
Writer.
I got the machine 2 weeks ago, installed it that weekend and recorded whth a
client on the Monday thereafter. it was quite embarrasing when you try and
write a clients CD in front of the client and the writer of a NEW PC gives
you errors the whole time.
I ripped the drive out and put my old 32X BTC drive in and the CD wrote
immediately. So there was nothing wrong with the Disc since the BTC used the
same disk and it wrote fine.
KC
"WillStG" <willstg@aol.comnospam> wrote in message
news:20040901023035.08240.00000102@mb-m18.aol.com...
Near the
burner
is
CD, and
many new
reinserted
bit, and
if
couple
> Will Miho
Reply to Anonymous
- 0 +
"cannone" <kevin@itsmusic.co.za> wrote in message news:<41357330.0@news1.mweb.co.za>...
> Writer.
> KC
> Near the
> burner
> is
> CD, and
> many new
> reinserted
> bit, and
> if
> couple
> > Will Miho
I believe most newer drives should be able to write to 1 to whatever
they say the highest is (highest being theoretical). If there was a
problem with discs it would be an older drive and a faster approved
disc. I've never had any problem with lower approved discs and a newer
drive so long as I burned at a slower speed. I still don't see how it
would be a software problem. The calibration is of the laser not the
software. Sounds to me like these Samsungs have a whole batch of bad
lasers.
Reply to Mike
There are 1489 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
