G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.action (More info?)
Just bought Delta force XTREME.
The game is awesome, especially for the original DF fan like me
The problem is the game resets my pc everytime and if I'm not mistaken
at the same spot of the first map of the first mission.
I only play single player only.
That happened before and after the patch.
My pc does not have any heat related problem as I can play other
system-intensive games for hours on ends: HL2, CS:S, Far Cry, etc...
I suspect a file corruption ( the .BMS file of the map), I did uninstall
and re-install the game, re-patched it, but the problem prevails.
Any help and suggestion from you is greately appreciated.
Regards,
Regards,
