Tom's Hardware > Forum > Audio > Pro Audio > Need help finding PC friendly quality audio recorder
Forum Audio : Pro Audio - Need help finding PC friendly quality audio recorder
Archived from groups: rec.audio.pro (More info?)
I'm working on a project where I need to record sounds, voices and
conversations that I'll reuse in a multimedia presentation. My
requirements are simple:
- I need to capture good quality audio
- I need to be able to download, edit and combine it with a slideshow
using Macromedia Flash
Minidisc recorders sound like the right hardware, but it appears that
it's very hard to export, convert and reuse those sounds on a PC.
I'd love your recommendation about the next best solution. Would a
quality MP3 voice recorder do it (may be with an external mic)? Any
specific brand I should look into?
Thanks!
pt
Sponsored Links
Others have recommended the Marantz card recorders which I have found
to work well.
Not sure of the Nomad Jukebox 3 has digital outs or not but Mike
Rivers speaks highly of it for outside recording.
On 2 Sep 2004 20:53:16 -0700, tosolini@gmail.com (Paolo Tosolini)
>Thanks!
>pt
Mike Cleaver Broadcast Services
Voice-overs, Newscaster, Engineering and Consulting
Vancouver, BC, Canada
radiovoiceone@hotmail.com
Reply to Anonymous
Firewire output, and I second the recommendation.
Reply to Anonymous
In article <k9shj0tuhge68m9jqo354vtgf6gk99one8@4ax.com> voice.1@telus.net writes:
It has USB and Firewire ports which allow copying of recordings as
files to a PC. It records in WAV or MP3 formats. I'd record WAV given
that the intent is to bring the audio files into a computer and edit
them.
However, since it doesn't really have a mic input (just the line input
with the gain cranked up 25 dB or so on the digital side) it's not
really appropriate to "record sounds, voices, and conversations"
without an external mic preamp.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
"Mike Cleaver" <voice.1@telus.net> wrote in message
news:k9shj0tuhge68m9jqo354vtgf6gk99one8@4ax.com
The NJB3's best digital I/O path to/from the PC is via Firewire and/or USB
1.1. It also has a optical digital input that is coaxial with the analog
line level input.
> or not but Mike Rivers speaks highly of it for outside recording.
With > 90 dB dynamic range and 0.1 dB frequency response via its analog I/O,
its really quite sophisticated.
It's weight, size and shape are dated, being CD-Player-like, but it has a
good reputation for robustness over the long haul, given that it is
2.5" )standard laptop) hard drive based.
NJB3's major omission is a proper mic input.
I use mine with a Behr MXB 1002, which is line/battery operable and has 5
mic inputs.
Reply to Anonymous
And it is out of production, heavy sigh. It looks as if
they've abandoned recording.
I've always thought the real problem there was how on earth
to get any signifigant and quiet gain in such close
proximity to the impulsive noise you get controlling
spinning motors and dumping and stopping big currents
suddenly into rotary ones.
Bob
"Things should be described as simply as possible, but no
simpler."
A. Einstein
Reply to Anonymous
"Bob Cain" <arcane@arcanemethods.com> wrote in message
news:chdi160292d@enews2.newsguy.com
Reading between the lines on the relevant Creative forums, their position is
that right now they are locked in a major struggle with Apple over
playback-only devices and there are plenty of NJB3s to buy if you know where
to look:
http://cgi.ebay.com/ws/eBayISAPI.d [...] 07532&rd=1
(Seller is none other than Creative Labs!)
That's all in the hard drive, which is just a commercial laptop computer
part.
Oh, and the answer to your question is:
Shielded motors, carefully-designed circuit cards with ground planes, and
low impedance circuitry.
Reply to Anonymous
Don't obsess on the transfer from minidisk to computer HAVING to be
digital. I doubt you'd actually notice the difference of an analogue
transfer.
CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
"Possibly the world's least impressive web site": George Perfect
Reply to Anonymous
Add a Denecke AD-20 or one of our Mic2496 dual mic pre/A-to-D and you'll
have a much better sounding system.
Len Moskowitz PDAudio, Binaural Mics, Cables, DPA, M-Audio
Core Sound http://www.stealthmicrophones.com
Teaneck, New Jersey USA http://www.core-sound.com
moskowit@core-sound.com Tel: 201-801-0812, FAX: 201-801-0912
Reply to Anonymous
You might have a look at our PDAudio system.
http://www.core-sound.com/HighResRecorderNews.html
Reply to Anonymous
In article <chfbat$k1r$1@panix2.panix.com> moskowit@panix.com writes:
I know that, and you know that I know that. I just want a one-piece
system with real mic connectors on it, not two or more pieces and
extra cables and adapters.
I wrote a yet unpublished and I suspect won't be published review of
the Core Sound Mic2496 preamp and I agree with Len - it sounds fine.
Reply to Anonymous
There are 1191 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
