i need to connect modem to computer with the length of 150m. suggest which way is efficient to connect. which cable is efficient. is any medium needed in between.
I'm assuming ethernet since you provided no details at all.
A single run is limited to 100m. To run further you must use an active repeater of some sort. Now you could go fiber but the cost goes up dramatically.
