Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Problems with 14" CRT
Forum Computer Peripherals : CRT Monitors - Problems with 14" CRT
First off, the computer in question is a P3 450 with 384MB of ram running WIN98SE.
With the old Starfighter 8mb AGP video card installed, the monitor was fine running at 800x600.
I installed a geforce 2 GTS 32mb and now the screen is acting like the refresh rate is wrong. I have tried changeing the refresh rate to no avail. I have re-installed the drivers more than once, and have had to go back to the old vid card.
Any ideas?? The monitor is a 14" NEC MultiSync 2A.
Spec:
Intel P4 2.4B
MSI 645E Max-U Mobo
512MB DDR333
GF3 ti200 64MB
SB Live 5.1
WD 60GB (Storage)
Maxtor 6GB (System)
Maxtor 120GB
LG 24x24x32 CDR
WIN2K PRo SP4
Sponsored Links
How old is that monitor?
I had an old multisync monitor (not an NEC) that is interlaced only. It doesn't normally work with my Geforce cards which default to non-interlaced resolutions. I made it work using Powerstrip and forcing the video card into an interlaced mode.
The problem was I needed to use a newer monitor to see what I was doing before I could hook up the old monitor.
<b>56K, slow and steady does not win the race on internet!</b>
Reply to phsstpok
it was used when I bought it 8 years ago :)
what is powerstrip? is it a program I can download??
I have a monitor switch box whch I can use to make changes using a newer monitor.
thanks. :)
Spec:
Intel P4 2.4B
MSI 645E Max-U Mobo
512MB DDR333
GF3 ti200 64MB
SB Live 5.1
WD 60GB (Storage)
Maxtor 6GB (System)
Maxtor 120GB
LG 24x24x32 CDR
WIN2K PRo SP4
Reply to sparky853
Yes you can download Powerstrip. I think <A HREF="http://www.entechtaiwan.com/" target="_new">this</A> is the correct website.
There is a shareware version.
I can't remember how to set the interlace modes offhand and I'm not at my computer right now.
I think it's somewhere under device profile or something like that. (I haven't used powerstrip for quite a while).
Reply to phsstpok
thanks. I downloaded the program. I'll let you know if it works.
Spec:
Intel P4 2.4B
MSI 645E Max-U Mobo
512MB DDR333
GF3 ti200 64MB
SB Live 5.1
WD 60GB (Storage)
Maxtor 6GB (System)
Maxtor 120GB
LG 24x24x32 CDR
WIN2K PRo SP4
Reply to sparky853
Quote :
I did the same since I haven't used Powerstrip for a while.
I discovered my present monitor doesn't seem to support anything but non-interlace modes which reminds me to mention this. The safety recovery hotkeys are CTRL + ALT + S. Just so you know, in case you pick an invalid monitor frequency (like I did LOL).
I learned the hotkeys only after I messed up my display and was forced to boot to DOS and then delete the PSTRIP.INI file so I could get back into Windows).
Powerstrip is more complicated than I thought when it comes to selecting custom timing. You might want to look for detailed specs on your NEC 2A.
Good luck.
Reply to phsstpok
Thanks. I just might need that. I haven't had a chance to test it yet, hopefully tonight.
Spec:
Intel P4 2.4B
MSI 645E Max-U Mobo
512MB DDR333
GF3 ti200 64MB
SB Live 5.1
WD 60GB (Storage)
Maxtor 6GB (System)
Maxtor 120GB
LG 24x24x32 CDR
WIN2K PRo SP4
Reply to sparky853
There are 1076 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
