Tom's Hardware > Forum > Smartphones & PDAs > Palmpilot > Zire72, audio output too loud
Forum Smartphones & PDAs : Palmpilot - Zire72, audio output too loud
Archived from groups: comp.sys.palmtops.pilot (More info?)
Hi,
Is the Zire72 supposed to have such a loud output through its headphone
jack? While I can control music volume, system sounds (even on the
"low" setting) are just *far* too loud. I have a gut feeling that this
is due to my simple (and cheap) earplugs. Would better earplugs help in
this?
Regards
-Laurens
Sponsored Links
On Fri, 14 May 2004 20:14:38 +0200, Laurens wrote:
> Would better earplugs help in this?
Not really. I've found that the better, more expensive ones tend
to be more efficient and are even louder. You can find models
having inline volume controls, from sources such as Sony, Radio
Shack, etc. I guess that these would be useful only if with the
system sounds volume set to the lowest setting, you could set the
music volume loud enough to compensate for the volume control's
attenuation.
Reply to BillB
Laurens <spam@block.com> wrote in message news:<c832ha$f1e$1@reader10.wxs.nl>...
> Hi,
> this?
> Regards
> -Laurens
i had a zire 71 before the zire 72 and it too had alarm and system
sounds that were just way too loud. I suggest you go into Prefs and
then adjust the system or alarms volume.
Reply to Anonymous
> Hi,
> this?
Yes, it's your ear plugs fault. It probably has a different ohm
level......try a different pair. Different Ohm-age (if that's a term)
can contribute to how loud headphones are.
Reply to christopher
There are 1010 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
