Help with wireless connection please
Last response: in Wireless Networking
Anonymous
Laptop Expert
Wireless Authority
My Dell laptop running windows 7 connects to the cisco router fine then it can not connect from the internet from there. The lap top that is connected to the same router but not wireless is fine. A hub and an extra router show up on the network for the laptop. I have no ide why. Any suggestions?
More about : wireless connection
Laptop Expert
Wireless Authority
Are you sure the wireless router you're connecting to is actually the same router that you're connected to when using wire? Is easy to be fooled into assuming it is, esp. if this is a work situation. It's entirely possible you're connecting to some other *internal* wireless router that doesn't have internet access, esp. if when you connect via wireless you see unfamiliar devices! It could even happen at home between neighbors if they both use the default SSID and leave wireless security disabled.
Anonymous
Laptop Expert
Wireless Authority
At the momet I'm not sure of anything any longer. I was able to see the laptop in the network on the desktop network but no longer can. I think it is time for me to give up after working on it for many hours and taking it to someone else just hope they can fix it we need it to take on a trip soon :(  Thanks for your help.
Ask the community
