Hey
I just recently bought a Telewell Wlan AP wireless access point and my problem is that I can't connect to the internet with Lan, hence can't get connection on my desktop. My laptop however works fine with wlan.
There's a wall socket which connects to a bigger student local network, I can connect my desktop to it directly and it works so there seems to be nothing wrong with my computer. I've had 2 routers before this, another Telewell that worked flawlessly and a Buffalo that cut the connection every now and then but didn't have this kind of problem.
I have the router plugged into the wall, set to get a dynamic ip (as it should be) and it does find Wan-side ip-address and dns-servers, as I could connect through wifi. So there doesn't seem to be a problem with that either. But for some reason Lan doesn't work. I can access the router through Lan, dhcp is on and I can see my desktop on the routers client list.
I'm quite clueless at this point and some help would be greatly appreciated.
-Janne
-Janne
