Tom's Hardware > Forum > CPU & Components > Sound Cards > Problem with sound card...
Forum CPU & Components : Sound Cards - Problem with sound card...
My comp's onboard soundcard sound output is very soft, barely audible even though I push the volume controls to maximum. Check the speakers and they work fine in another comp. Does anyone know what's wrong with my sound card or any program that can pump up the volume further?
Sponsored Links
Try amplified speakers, if you're not using them, if you are, try going to a different soundcard.
Details, Details, Its all in the Details, If you need help, Don't leave out the Details.
Reply to 4ryan6
Is there an newer driver on the manufacturer's web site?
Reply to upec
Double check exactly which output jack you have your speakers plugged into. I once had onboard sound with two jacks, one CLEARLY labeled "Output". It was actually the input for a microphone. I had the exact same problem you did when I hooked everything up by the book.
Plugging my speakers into the "microphone" jack fixed all my problems.
Reply to letdown
There are 1204 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
