Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I am trying to install the software for my new MN-500
router. The wizard fails because it says I do not have
the universal plug and play enabled. I went throught the
control panel and believe I made sure the UPnP was
installed correctly. However the MN-500 software wizard
keeps getting the same UPnP error. I am running XP.
Help?!?
Check in Control Panel/Administrative Tools/Services to make sure UPnP is
not only enabled but running.
Chris H.
Microsoft Windows MVP
Tablet Creations - http://nicecreations.us/ Associate Expert
Expert Zone - www.microsoft.com/windowsxp/expertzone
"LMK" <anonymous@discussions.microsoft.com> wrote in message
news:73ea01c430cf$c8dc97c0$a401280a@phx.gbl...
> Help?!?
It says it is disabled. From that screen I tried
switching it to manual and to automatic and starting it
but it didn't work. I get the message "Could not start
the Universal Plug and Play Device host service on local
computer. Error 1068: The dependency service or group
failed to start"
>-----Original Message-----
make sure UPnP is
I'm sketchy on this so please correct me if I'm wrong. I
remember that SSDP has something to do with UPnP. My
SSDP was disabled. I changed that to manual and started
it. Then I changed the UPnP to manual and started that
and it started this time. Should I leave my settings
this way or do I switch them back if I am able to get the
router installed?
make sure UPnP is
>Chris H.
>Tablet Creations - http://nicecreations.us/ >Associate Expert
>Expert Zone - www.microsoft.com/windowsxp/expertzone >
message
the
wizard
>> Help?!?
Sounds like you've altered your Services settings. I would set it to
Automatic. Right-click, and the menu will give you the settings. Leave
them that way, they're necessary for the proper operation. While there,
make sure Wireless Zero Configuration (down near the bottom) is also started
and running (Auto).
Chris H.
news:74ae01c430d6$97406190$a601280a@phx.gbl...
> router installed?
> make sure UPnP is
>>Chris H.
>>Tablet Creations - http://nicecreations.us/ >>Associate Expert
>>Expert Zone - www.microsoft.com/windowsxp/expertzone >>
> message
> the
> wizard
>>> Help?!?
The Simple Services Discovery Protocol (SSDP) service is the one required
for any operation involved with discovering and interacting with UPnP(tm)
technologies. If it were disabled, this explains both of your problems
(even having it in Manual mode would have allowed it to start when
required). For a small environment, you will want to leave this service
started and in automatic mode. The UPnP Device Host is not required for
interaction with the Internet Gateway Device (IGD), but you should have no
problems with leaving this in automatic mode as long as you have all of the
Windows XP updates installed and it will provide some nice additional
functionality if your other machines on the network also have these services
running. As you can derive from its name, SSDP is the lower-level service
that provides the ability to automatically discover UPnP-based devices and
services. The UPnP Device Host service requires it to be running in order
to operate.
The UPnP Forum has put a new "all-in-one" download of the current UPnP
standards, Device Control Protocol (DCP), and architectural documents at
http://www.upnp.org/resources/documents.asp if you want more information.
Regards,
=D-
Derek R. Flickinger
Interactive Homes, Inc.
> router installed?
> make sure UPnP is
>>Chris H.
> message
> the
> wizard
>>> Help?!?
news:779b01c43119$18748790$a601280a@phx.gbl...
> Thanks Chris and Derek. I'm up and running with a
> wireless connection! Hooray!!
