Solved
How do I know if I have power over Ethernet?
I work in IT and I'm trying to install a network camera for a client which requires power over Ethernet. How do I verify that there is not PoE available, or whether the camera is defective? (I'm pretty sure that there is no PoE; I just want to be able to prove it.)
8 answers Last reply Best Answer
More about power ethernet
  1. Get the model number of the switch, look at the specs on the manufacturers website.
  2. What about plugging directly into the wall?
    Plugging what directly into the wall? If your talking about plugging the camera into a network drop, all that means is the camera is not receiving power, either due to no PoE or due to bad cabling.
    Right, I want to literally *PROVE* that there is no PoE at my client's office building. Is there a way to perform this?
  5. Best answer
    Not without a somewhat sophisticated test rig. There won't be any power on the line if certain conditions aren't met. Best bet is to identify the switch and look up the specs.
    http://en.wikipedia.org/wiki/Power_over_Ethernet
  6. Have to concur that you are going to have to get a look at the switch. Even if it is a PoE switch you can still not have power. The port could have PoE disabled in the configuration and you also get the nasty case of what looks like "random" power availability.
    If a PoE switch does not have enough power in the chassis to provide power to all the ports it will just stop offering power when it runs out. Then if someone unplugs their device a different port may then request it.
  7. Thanks all. The client is looking into purchasing a PoE injector for the network camera to absolutely ensure that it will be powered correctly. Thanks again.
  8. Best answer selected by Paul22000.
Cameras Ethernet Card Power Networking
