Tom's Hardware > Forum > CPU & Components > Other Components > What power supply is enough or too much?
Forum CPU & Components : Other Components - What power supply is enough or too much?
I have a pentium 4 2ghz with 2 hard drives at 7200 rpms and a geforce 4 ti graphics card. Also there is 512 mb rdram and 2 cd drives. I was wondering what is the best power supply to get for this.
Thanks
Mike
Sponsored Links
350-400W, Antec or Enermax.
What if you had admin rights to life?
Reply to Flamethrower205
I just got two antec truepower 430watters. I love them. A month or two ago I posted a thread entitled "power crazy?" where I questioned needing so much power, but I finally gave in, and I am glad I did.
Reply to mattburklund
I would recommond Enermax EG465P.
Reply to upec
Is the EG465AX a better version of the EG465P?
Reply to Vince604
I'm also thinking about getting a new power supply as I have a cheap L&M one that came with my case. My main concern is cooling. Which 430 PS would do the best job between the Enermax and Antec? Also, where would you recommend ordering it from? Thanks.
Krycek
Reply to akrycek
Well in terms of cooling it's really your preference.... The better the cooling the louder the fan usually gets. But both companies Antec and Enermax have a thermal feature which controls how fast the fan should go under high loads and will slow down when it's not necessary so it's up to you. I just might wait a little while longer and hope for Vantec to come out with their Stealth Power Supply which looks pretty promising.
Well where you want to order it depends on where you live...
Reply to Vince604
You can't have too much power.
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
Reply to Crashman
Vince604, I would say yes.. The AX supplies are "Active PCF" supplies which means:
Power factor is the ratio of true power (watts) divided by apparent power (volts x amps or VA). A standard power supply has a power factor of 0.70-0.75, while a power supply with active power factor correction (PFC) has a power factor of 0.95-0.99. A power supply with power factor correction is better able to convert the current into power. This results in lower peak current and lower harmonic current, putting less stress on wiring, circuit breakers, and transformers.
<P ID="edit"><FONT SIZE=-1><EM>Edited by The_Bear on 09/14/02 12:58 PM.</EM></FONT></P>
Reply to The_Bear
Ah alright thanks. So basically the Active PCF series would give a more power efficient performance vs. regular PSUs?.. I'm really tring to decide to either go for the Enermax EG465AX-VE FMA 433W or the Vantec Stealth 520W PSU?
which one would you guys go for?
Reply to Vince604
*SQUEEEEEEEEEEEEEAK*
i dont think it would really matter with such a high powered psu... unless u added some peltiers LOL
u can allways do what i did when i couldnt decide... i just purchaced the most powerful one i could get my hands on... 550W enermax baby!
runs super quiet and very cool.
<b>Small.Cute.Fluffy.Evil. And Creator Of Perminant Hearing Loss If Ever Used As A Qtip!</b>
Reply to EvilHammie
More efficient was one of the reasons, but the fact that it was less prone to spiking, keeping the feed to the system more consistent (less stress on components) was the key for me. You could always go with the biggest, but the 465ax-ve fma ( I went with the FCA which has the motherboard control over fan activity) is a very nice PSU (BTW this is a black PSU which went well with my case(and no that was no the reason).
<P ID="edit"><FONT SIZE=-1><EM>Edited by The_Bear on 09/18/02 10:55 PM.</EM></FONT></P>
Reply to The_Bear
Well would you ever really need 550W of power? Is it worthwhile to spend the extra bucks? Or a 430-450W PSU is more than enough already?..
Reply to Vince604
Well the 430 seems enough for things you could cram in a mid-tower case. I mean I have 2 hard drives, 2 optical (DVD drives), a 3.5 floppy, a smart media card reader (internal)and the 6 case fans. It seems more than strong enough, but I don't know of a tool that will tell me how much power I'm using.
Reply to The_Bear
okay that seems enough for my cpu then... So what is the point of all these high powered PSU if not being used in a server enviroment?
Reply to Vince604
Well that was my feeling...unless you are setting up a full tower with 8 IDE devices or more, use all your card slots, I just can't see the reason for that large of a supply.
Reply to The_Bear
For most system 430-450W will be enough.
Reply to upec
Boy I don't think I can ever do that.
How about the fan noise though?
Doesn't a PSU that can handle a lot more will have a lot less stress on the parts inside the power supply? Meaning it will run cooler and require less airflow?.....
Reply to Vince604
There are 680 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
