Tom's Hardware > Forum > CPU & Components > Other Components > Tubing for power supply and IDE
Forum CPU & Components : Other Components - Tubing for power supply and IDE
ok,I've been looking for the tube for a long time..but I still can't fine them..
This link shows a black one...
http://www.xpcshop.idv.tw/Digitalcase.htm
This one shows the zinc one....
http://www.xpcshop.idv.tw/DigitalLibraCaseP2.htm
I only got those heat shrink tubes in The Lowes, but they don't have that kind of tube (or net)
In the picstures all the IDE and power supply are organized so well...
Sponsored Links
you can order the rounded IDE and Floppy cables from places like Newegg.com or wherever. Just make sure if you order the 2-connector rounded floppy cables that your computer/motherboard BIOS will be able to recognize the floppy drive while plugged in.
Otherwise, the other stuff looks like its just basically like an elastic-type covering for the power cables. A neat and clean way to keep things, but a pain in the rear to get on the cables how you want them to.
I'd just order some color tie-wraps...since they are pretty cheap and easier to work with (IMHO).
[If loving AMD processors is the path to the Dark Side, consider me a Sith Lord. (dinoX aka Black Dog)]
Reply to dinoX
Try following the link in the Fabric Tubing thread. What you are looking for is described there....
<A HREF="http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=56008#56008" target="_new"> Fabric Tubing </A>
doh! Just noticed that you found it... enjoy, it wasn't easy to find.<P ID="edit"><FONT SIZE=-1><EM>Edited by The_Bear on 09/14/02 01:07 PM.</EM></FONT></P>
Reply to The_Bear
There are 1118 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
