Tom's Hardware > Forum > Mobility Brands > Motorola > HS810 Bluetooth Headset Problems
Archived from groups: alt.cellular.motorola (More info?)
Hi all,
I have a HS810 Bluetooth Headset and its a right pain in the ar*e!
When its fully charged it seems to work great for about 2 hours on
standby (with boom open) but it is for ever disconnecting and
reconnecting - sometimes during calls.
After a while it will disconnect and then simply will not reconnect.
Is this a battery problem?? The manual says 5 hours of talktime and
100 hours of standby time. i might get 1/20th of this if i'm lucky.
I have heard that this is a common problem - is there any claim
options on the warrenty - maybe a swap out for the new HS820 model??
For the record its connected to a Nokia 6310i.
Regards,
Jon
Sponsored Links
"Jon" <jonathan.kelly@no-spam-linesurveys.co.uk> wrote in message
news:cl2ph0h5ccgmrrvaugjok1u0vm8ji13vpm@4ax.com...
> Hi all,
> Regards,
> Jon
What is the firmware version and date of your 6310i? (*#0000# from standby)
Do you have another handset to try it with? This would eliminate the problem
being your 6310i (which has been nothing but trouble on early firmware
versions).
Antz,
Part of the UKtm family
Reply to Anonymous
- 0 +
Dont know what this means, but this is what it says. Is this early or
late firmware??
Firmware Version:
V 5.50
03-03-03
NPL-1
(c) NMP.
As for trying on another phone, the mrs has a T68i. It works on that
phone in a similar fashon to the 6310i. To be honest though I havent
used it enough to know if I gat the same results.
Jon
On Fri, 13 Aug 2004 14:22:10 +0100, ">-©LuVbuG©-<"
>> Hi all,
>> Regards,
>> Jon
>versions).
Reply to Jon
news:rbiph05gbdd6nfkcakec4fd6vcgsf8aoa9@4ax.com...
> late firmware??
> Firmware Version:
> V 5.50
> 03-03-03
> NPL-1
> (c) NMP.
> Jon
The firmware of your phone should be OK.
The only thing would be to use it with the T68i and see what kind of
standby/talk time you're getting.
Hope this helps,
Antz,
Reply to Anonymous
There are 625 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
