Archived from groups: rec.audio.pro (
More info?)
Hey Guys,
Thanks for the ideas so far. I've ran an extension cord to other
rooms for the tv, no change. But, when I moved in here, I noticed
that on a wall receptacle there are the normal 2 vertial plugs, but
the screw in the middle had a bit of wire wrapped around it. Wonder
if the previous home owner used that as a ground? On the back of my
Yamaha receiver I have a GND terminal, just a little knobby thing I
can unscrew and pinch in some wire. In the manual it says it's for
turntable use, then later on says "connect to a good earth round like
a metal stake driven into moist earth".
Hmm so how do I create a round, do I just run a piece of wire from
that GND terminal on my Yamaha receiver to something? Forgive my
ignorance, I'm not an electronics guy at all.
Thanks muchly!
S.
On 20 Sep 2004 08:23:32 -0700, karlwinkler66@yahoo.com (Karl Winkler)
wrote:
>bruwhaha58097238@aol.com (Raymond) wrote in message news:<20040919234620.03961.00004022@mb-m19.aol.com>...
>> > skydigger123@hotmail.com
>> >Date: 9/19/04 9:09 PM Eastern Daylight Time
>> >Message-id: <9dbsk01o5glrvgb40p5rlvelkbbohr3ffj@4ax.com>
>> >Hoping one of you audiophiles can help me with this one:
>> >I have a good quality Yamaha surround home system. When I had it
>> >plugged in through my older Hitachi 27" tv set, I could turn on the tv
>> >no problem.
>> >Now that I have it hooked through my roommate's 32" Zenith tv, when I
>> >turn on the tv or turn it off (his Zenith) there is a loud POP! that
>> >comes out of all the speakers, and I know that's not good for the
>> >speakers. What might be causing that? Is there something I can do to
>> >fix that?
>> >I also notice the speakes crackle when the furnace turns on our off as
>> >well. Argh!
>> Well, we are mostly recording studio guys but this sounds like a ground issue.
>> Try plugging into a different AC outlet? Tried a power conditioner (not sure if
>> that will help or not)? You can hirer a contractor (electrical) to come in and
>> run a dedicated outlet for you.
>I agree it's a power issue. You may be running close to capacity for
>amperage on the circuit that you are using for the stereo. When you
>turn on the TV, the initial "short" presented by the power supply
>transformer in the TV momentarity presents a power spike (back EMF)
>just after.., and therefore a spike goes onto the power line and then
>through your stereo.
>A power conditioner for the stereo should help, but don't get a cheap
>one. Also, I'd suggest running the TV off a different circuit. It may
>be worth having a dedicated circuit installed just for the stereo.
>Karl Winkler
>Lectrosonics, Inc.
>http://www.lectrosonics.com
