Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound Volume Level To Low
Forum CPU & Components : Sound Cards - Sound Volume Level To Low
I just bought a Hercules Muse 5.1 DVD card,
the drivers for it sucks quite alot..
But anyways, now I'm running with the chip-manufacturers (c-media) drivers.. but 1 problem is still there...
The Windows audio-mixer Master volume doesn't work like it did before.. (in windows2000 its pretty sensitive and can be quite high) .. its at maximum now .. wave too .. and since I changed card I have had to raise my 2 stereo's 6 times the volume I had before, to make them sound as high as before...
And having such high volume makes alot of static sound when not playing stuff also...
It's really a pain in the ass...
So if someone knows how to raise the max volume in Windows / the mixer .. (through registry or something) .. Please help..
P2 300mhz / 768mb ram / 40+46gb hdd / Windows2000-Server / DirectX 8.1
Sponsored Links
Just a comment:
I don't have the same card, but I've got something similar, the Game Theater XP 6.1.
I noticed that when the "Enable Stereo Expansion" option was checked, my sound level dropped drastically.
After disabling that, I installed an "Enhancer" plugin for Winamp 2.xx that added a 20db boast. After setting the speaker volume at a normal level, now I can't play anything over about a 7% volume level in Winamp without blowing myself out of the room.
It's worth a look, if you'd like a little more volume, and would also like a customizable reverb. <A HREF="http://www.i-adrian.home.ro/enhancer.htm" target="_new">ENHANCER</A>
Toejam31
<font color=red>First Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=17935" target="_new"><font color=green>Toejam31's Devastating Dalek Destroyer</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
________________________________________
<A HREF="http://www.btvillarin.com/phpBB/index.php" target="_new"><b><font color=purple>BTVILLARIN.com</font color=purple></b></A> - <i><font color=orange>A better place to be</font color=orange></i>. :wink:
Reply to Toejam31
ok .. will look for that .. thx :)
but the enchancer wont solve the problem though ..
since its not only mp3s im out to play loud...
Reply to jwesterlund
There are 1072 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
