Hello,
I recently overclocked my system a bit and had to reset the CMOS settings quite a few times, couse i increased the FSB too much. Now im running a 1000mhz AMD Duron @ 1100mhz (110fsb x 10.0mp) couse that was the most stable setting i got.
But after i was done with my clocking, i saw that i had 128DDRAM instead of 256DDRAM (because i have 2x 128DDRAM's installed).
I walked thru the BIOS settings and got the same 128RAM everytime.
Well i thought maybe i somehow gave "static electricity" to the RAM (i took it out 1 time because i saw a price tag on it, probably the guys to sold me the PC forgot to take the price tag off the ram, and i removed the tag).
I went and bought another 128DDRAM and today carefuly with rubber gloves inserted it to the SLOT number 2, and the other RAM (that i thought was not working) I inserted to the SLOT number 3, Again i got 128RAM, not 256 or 384 that i should have with 3x 128RAM.
I haven't taken the SLOT1RAM out because my 3D CARD is in the way of the small switch i have to press when i take the ram off. But as it seems the SLOT1 and the RAM are working fine. Well i tried to put the new RAM i bought today to SLOT3: and still no change...
I know that SLOT1RAM is working couse when i take all the other RAM's out, i still have 128RAM that is in the slot1.
I checked SISOFTWARE SANDRA and it shows the memory modules, nicely and correctly: though i dont gain RAM,
i still have the same 128RAM from the SLOT1RAM.
Im totally confused, i dont understand what the problem is:
I see the ram i insert to slot2/slot3 in the module list but i dont gain any RAM from it... so it proves the slots or rams are'nt totally scr**ed.
Could anyone give any hints, maybe i should do some "jumper-changing" or smth else?
