Hello all. Hope everyone is doing well today
I dont particularly stick to support forums, but since this issue is really unique to me, I am hoping someone can fill me in with some help
As of recently, I just upgraded my system to the following configuration:
Intel i5 2500K 1155 socket CPU
Gigabyte Z68A-D3H-B3 revision 1.3 mobo
8GB Corsair Vengeance DDR3 1600 RAM
(2) 60GB OCZ Solid 3 SSDs (One for each partition that I'm running on my system)
2TB Western Digital SATA HDD
nVidia GeForce GT430 2GB DDR3 graphics card
Rosewill RD 500-2SB 500 Watt PSU
Rosewill Challenger Mid-Size ATX case
Prior to installing the software, I had tested the memory, CPU, HDDs, everything. All checked out OK.
My system hosts two SSDs to run two partitions: One is Windows 7 Ultimate 64-bit, the other being Windows XP Professional 32-bit. The additional 2TB HDD is basically to store the tons of data that I have on, and I use the Windows 7 My Documents folders to have everything map to the HDD to acquire my data, download to it, etc.
The issue that I seem to be running into, is that every time I load up the Windows 7 partition, no matter how long I leave everything running, if per say I was to leave it running overnight, when I wake up in the morning, it will show that the PC has rebooted. Upon checking the event viewer, I am seeing multiple entries specifying that the error was caused by a kernel-power error, listed as event 41. Reviewing this info, I later noticed that it was causing a bugcheckcode of 265 everytime the issue occurs.
Ideally, I would like to think that it was hardware related, or driver related, as it mostly occurs when I play movies or videos, but when I boot the Windows XP partition, I never come across any of these issues whatsoever. Granted, the XP partition is used primarily for work when I do remote stuff from home, but granted I want to watch a movie on it I can also. Also, when loading the eventvwr on the XP partition, no kernel-power entries are listed.
So clearly, this is occuring on the Windows 7 partition, and not the Windows XP partition. Since I dont really think this is due to hardware issues, I am requesting for some advice on what I can do, or what I can upload here, to have reviewed and followed up with a suggestion. Thank you!
