Yes No
Ads
Tom's Hardware > Forum > Home Audio > Pro Audio > - Audio card recommendations for home recording?
Forum Home Audio : Pro Audio - Audio card recommendations for home recording?
Archived from groups: rec.audio.pro (More info?)
I've been using an Echo Gina20 for my Sonar recordings for, well, what seems
like forever... I will soon be upgrading the ol' computer and wanted to
upgrade cards as well.
Is there a new standard for that price range? Or should I go with an echo
again?
I was told the top-line Creative cards have caught up to the point of
becoming an actual player in this field. This true?
Your recommendations are welcome (no $1,000 cards please... let's stick to
the Echo price range, which is as high as I can go).
Many thanks!
Reply to Anonymous
On Wed, 22 Sep 2004 09:55:46 -0400, "W. Forsk" <newsgroup@only.com>
Take a look at Terratec range.
Reply to Anonymous
>again?
I'd stick to the Gina, unless you want more ins/outs. The M-Audio
equivalent is currently selling for a very attractive price. But it
won't sound any different to your Gina.
No.
>Many thanks!
CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
"Possibly the world's least impressive web site": George Perfect
Reply to Anonymous
In article <2rdeisF19d4c9U1@uni-berlin.de> newsgroup@only.com writes:
> again?
Why do you want to upgrade your sound card? Are you upgrading other
equipment as well and need a different I/O configuration? I'd hang on
to what works and spend your money elsewhere. The Gina is just fine
for any reasonable home recording project.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
> again?
How many channels?
Creative owns Emu, and I understand the Emu cards are okay. Stay away form the Creative-branded stuff for pro work.
Lynx Two is (barely) under $1k and you can't do a whole lot better in terms of audio quality <http://lynxstudio.com/lynxtwo.html>
RME HDSP9632 is another one to check out <http://rme-audio.com/english/hdsp/hdsp9632.htm> Under $600 with two analog I/Os, can be expanded with more as needed.
Those are the two brands I would pick above all others for pro work.
Reply to Anonymous
"W. Forsk" <newsgroup@only.com> wrote in message news:<2rdeisF19d4c9U1@uni-berlin.de>...
> again?
> Many thanks!
I just sold a Gina24 and replaced it with a Lynx L22. The Lynx sounds
so much better than the Gina24. However, I've owned two Echo cards
and they are rock solid. Lynx doesn't have a production WDM driver
either, so I'm using the ASIO driver in Sonar 3. I bought my Lynx L22
at GC for $655.00. Once I got it working, I had one of those "I
should have done this years ago" moments. :> )
DaveT
Reply to Anonymous
Unless you need different I/O (more ins/outs, ADAT in/out etc) theres little
reason to change the Gina 20. It sounds just fine! Go buy yourself a LOAD of
booze with the cash instead!
Martin
news:2rdeisF19d4c9U1@uni-berlin.de...
seems
> again?
> Many thanks!
Reply to Anonymous
Hi there,
> again?
You could do both. If you are looking to upgrade your card just for
the sake of it, you might want to check out the brand new Gina 3G from
Echo. It's a 24bit card with better converters than your Gina20, and
it's very reasonably priced with street price at around $300-350 new.
It also has two preamps in it.
From my experiences with Layla20 and what I've heard about Echo from
other users as well, you should be happy with their cards, especially
this one.
Kalle
Reply to Anonymous
On 22 Sep 2004 15:29:21 -0700, psychodave.thomas@gmail.com (Deaf
In any particular way?
Reply to Anonymous
"Mike Rivers" <mrivers@d-and-d.com> wrote in message
news:znr1095870220k@trad...
>> seems
>> again?
The author mentioned that it was a Gina20. He might be looking for an
upgrade to 24 bits.
Reply to Anonymous
In article <k0Y4d.68687$z74.698978@wagner.videotron.net> nospam@please.com writes:
> upgrade to 24 bits.
Why? What does that buy you? For the price range he's looking in,
maybe a couple more bits. Those will get lost in the noise of a
typical home recording setup.
Reply to Anonymous
>> for an upgrade to 24 bits.
That was my opinion too until I started comparing parallel 16 bit 48 kHz
and 24 bit 44.1 kHz recordings of the output from the same mic pre. The
spatial decay appears to me to be more natural in the 24 bit recording.
This however is about subtleties, upping the sampling frequency probably
does more than upping the wordlength and not all will feel that either
really matters if at all much.
Kind regards
Peter Larsen
* My site is at: http://www.muyiovatki.dk *
Reply to Anonymous
In article <415FA1BA.45C57016@mail.tele.dk> SPAMSHIELD_plarsen@mail.tele.dk writes:
Of course. And that's the sort of thing that someone with your level
of experience would notice if you went looking for it. Someone asking
a general question about a simple home recording setup is hardly
likely to notice, or even care about those differences. The same
amount of money spent elsewhere could be more noticeable, and
therefore more effective.
Reply to Anonymous
Mike Rivers wrote:
> .... The same
Indeed, Mike, indeed ...
Kind regards
Peter Larsen
Reply to Anonymous
On 2004-09-22, W. Forsk <newsgroup@only.com> wrote:
Get an M-Audio card and be happy. The Delta A/P 2496 was made in heaven
by angels.
Reply to Anonymous
On 2004-09-22, Laurence Payne <l@laurenceDELETEpayne.freeserve.co.uk> wrote:
> They've just been bought.
Uh-oh. So much for the only serious choice. I hope they don't go
either way -- more consumer-y or total pro$$$. The price point on the
Delta 1010 is perfect, and the hardware itself is the cat's meow.
Reply to Anonymous
Headroom in the dynamic range?
Before the computer entered the picture, would you have ever argued
against something that increased your headroom in any domain?
I believe my 16 bit recording is better for having been done on a 24 bit
device.
Reply to Anonymous
On Sun, 07 Nov 2004 23:36:22 GMT, james of tucson
>device.
You don't really get headroom. You don't own a source that has 16
bits of dynamic range, let alone 24. What it does give you is a
bigger window in which to place the range you CAN supply. It lets
you be sloppy with record levels without falling into the noise floor.
Not that this isn't useful :-)
Reply to Anonymous
In article <slrncotccr.7ha.fishbowl@radagast.home.conservatory.com> fishbowl@conservatory.com writes:
Depends on how much headroom I needed and how much it cost. In a pop
music world where dynamic range on recordings is limited (literally)
to less than 6 dB, is it asking too much of the engineer to set
recording levels and internal mixing levels so that a system with a
potential dynamic range of 96 dB will allow him to make good
recordings? We didn't have insurrmountable problems with headroom back
when we were using analog tape with 30 dB less headroom. Even
classical recordings today have far less than the full dynamic range
available.
Where most people run out of headroom is at the mic preamp or the
input of the A/D converter. Why? Because they want to turn on all the
bits for fear of losing resolution. Back off a couple of dB, lose the
clipping, and even at 16 bits, you'll still have a low enough noise
floor that you can make a recording with more dynamic range that any
reasonable listener can accommodate.
> device.
I wouldn't doubt it, but that may be because the 24-bit device that
you're using today is just plain better overall than the 16-bit device
you used previously. While it's true that using 24-bit resolution
allows you to be more conservative in setting levels while not running
out of headroom, if you want a certain output level of the final
product, by recording at a lower average level and boosting on the far
end, you'll boost the neighbor's leaf blower that leaked into your
room, or the barking dog, or the mic preamp's noise, or even the long
sought after room ambience.
It's your responsibility to control all of those things, and not
everyone thinks about that when using gear that "should be" better.
Reply to Anonymous
> to less than 6 dB
I play and record classical (and classical-ish) piano and flute.
I cannot tell any difference between takes at 16 and 24 bit on the same
equipment, but I don't care. I have 24 (32) bits available in my
digital signal path, and I'm not out of disk space or anything.
Until a couple of years ago, I was using consumer cassette tape, so
everything sounds good to me :-)
I'm going to agree with you, but I'm not seeing any argument that would
support buying a 16 bit recorder in this day and age. Particularly when
I already have adopted the Deltas as the only serious choice :-)
Reply to Anonymous
There are better sounding options from RME and Lynx that don't cost all that much more.
Reply to Anonymous
There are 1451 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Should I turn my speakers off to avoid damage?
By mubin, 1 day ago:
Do you mean when jack is connected then there is that noise? Then it is the cable. In my...
Best offers
Top experts
