Solved
Please Help Win 8 problems
Hi Guys, i was looking to downgrade back to win 7 due to bad compatibility issues with games. I'm struggling on how to load up win 7 setup from CD as a main boot device, i'm currently using a Toshiba Satelite P850-31L any help would be appreaciated, thanks.
1 answer Last reply Best Answer
More about please problems
  1. Best answer
    Hello,
    in order to enter into the the BIOS setup of your laptop press F2, Del key, or the key that your laptop displays while booting the system. You can also launch boot menu screen directly by pressing F9 or F10 key, and select CD/DVD Drive option to boot the computer with the DVD support. For further step-by-step instructions, click on the below given link. It should probably work.
    http://www.tomshardware.com/faq/id-1653279/downgrade-windows-windows.html
    Hope this helps.
Windows 8
