Tom's Hardware > Forum > CPU & Components > Other Components > can sound card over heat? or just a driver problem
Forum CPU & Components : Other Components - can sound card over heat? or just a driver problem
this might sound funny..but if I play FPS game long enough
my computer will freez wiht a high pich tone
back in the days it happens after 2 hours of CS game play.
first I thought its a over heating problem since I overclocked the vedio card a lil,
to eliminate taht I got myself a Lian-Li PC60, total of 5 case fans
2 front 1 top 1 back, and also the enermax PSU fan
should be no problem, max load is about 38 for system and 48 for CPU
I also updated my the drivers for my video card and sound
card, the freez rarely happen since then. but now...
I got the same problem after an hour or so playing UT2K3 demo
with Hercules 3D Prophet8500 128mb not overclocked, it seemed
like the problem is from the sound card, it is possible..
Since the card is SB audigy, bad rummers about their drivers
So..what do you think, what might be the problem?
a. UT2k3 demo is unstable, and will cause errors?
b. SB Audigy driver has done it again!
c. The Audigy card in this case is a crappy sound card
http://www.geocities.co.jp/College [...] index.html
Korea....good sport?
Sponsored Links
try the card in another system 2 see if it cause the same problem, what about bios setting? and all the other drivers? are they all updated? maybe bad memory? try to pin point the problem by swap components... etc
Reply to 10GHZ
Gee, before I opened this post I saw the title and thought "must be another Live! complaint". Well, the audigy is close enough. I had similar problems with the Live Platinum 5.1, and it was caused by the drivers. I sold it.
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
Reply to Crashman
well there you go. update the driver and see what happens. i'm using a SB Live 5.1 and i havnt run in2 any problems since i bought it
Reply to 10GHZ
Like I said, I sold it. Owned for over a year with no improvements in drivers.
Reply to Crashman
There are 1140 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
