Out of the blue my freshly build HTPC can't be used to stream from. It is driving me nuts.
The HTPC is just a regular PC running W7 Ultimate with XBMC.
I can transfer any file to it and it will be transferred at the normal speed. If I try to open, on my main PC for example, any mediafile like an .mkv or .mp3 the item won't even load. If I open the HDD from any computer in the network browsing it is really slow: it takes forever to open a folder.
I think it must be the LAN, since the HTPC plays any file without a problem, and transferring files to the HTPC's HDD is normal as well.
HD Tune gives me this:
Any ideas? I am sure out of any.
