Hi there,
Im building a system out of spares and ive just added a lucent win modem. When i turned on the comp it all installed ok in windows. However, when I restart the comp freezes at the win 98 load up screen. I wondered whether this was power but it want (tried 350 watt PS) and have come to the conclusion that it must be irq. In bios i tried changing a few things. so....
P n P OS - On/Off??
Should I auto the IRQ's?
Option for modem IRQ, doesnt effect the irq at all?
Im a bit confused and it seems that its really unstable. its all fine without the modem and the strange thing is that if i reset after it freezes the modem doesnt appear in the startup irq list, or windows system devices. but does appear in windows modems. However if I turn off the comp completely it reappears, i can get into windows, it reinstalls but if I turn of and then on it freezes again..
can someone plz help me?
UPDATE: I just took out the modem and decided to put in an ISA SB16 card to test if it was power etc. anyway.. the sound card doesnt appear in bios irq list, but when i get into windows, it starts reinstalling everthing. the floppy controller, the sound card and some other stuff. But after this everything works perfecly, no random craashs etc etc.
BTW, before when I started up, the video card would produce bright screen flashes after the ide detection, it doesnt do this anymore...<P ID="edit"><FONT SIZE=-1><EM>Edited by tombance on 09/27/02 10:04 PM.</EM></FONT></P>
P n P OS - On/Off??
