Hi everybody,
I have an IBM Deskstar 40 GB hard drive in my hand now. When i hooked up everything and tried to boot, the screen indicated that it couldn't detect any hard drive. I think I have set all the jumpers (to be master) correctly, if the hard drive is not detected, does that mean it is broken? is there any other way that i can find out? I am really desparate right now, so please help~
By the way, here is the jumper thing located behind the drive:
9 1 2 3 4
X 5 6 7 8
--Note: x is not a slot at all, pin 9 is by itself
the diagram suggest that if i connect (1, 5) and (4, 8) together, it will be fine. However, i have tried that, and it doesn't work, so i really have no clue about it =(
Thank you so much
Invisible
9 1 2 3 4
X 5 6 7 8
Thank you so much
Invisible
