Making PC Wireless wifi
Hello,
i am getting internet from someone by a LAN cable. the lan Cable is connected to my LAN Card (RJ45).
i bought a IPAD. and i want to browse using IPAD. IPAD needs Wifi connectivity.
can i convert this existing setting to browse internet from my IPAD?
1 answer Last reply
More about making wireless wifi
  1. Is the Ethernet cable coming from a modem, switch, router?
    If the cable is coming from a router then all you really need to do is purchase an Access point, or wireless router and disable DHCP if the cable your using is already connected to a router with DHCP.
Configuration iPad LAN WiFi Cable Internet Wireless Networking
