I bought the ASUS RT-N56U router and tried to set it up on my PC running Windows Vista. I used the ASUS provided CD and went to ASUS Utilities, used the default LAN IP address of 192.168.1.1 and default "admin" for username and password. Went as far as Wireless security level (WPA-2 Personal, and in the end I still could not get an internet connection.
I got on the phone with ASUS tech support and the patient techie spent over 50 minutes with me, tried everything and finally she said that there is a known issue between the ASUS router and Windows Vista. Does anyone ruynning Windows Vista have a similar problem, and if so, how was it solved?
My options as i see it are:
1. Return the router to Amazon.com for a refund
2. Buy another brand router, like the Linksys 2500 (not dual band, but I can live with that)
3. Upgrade to Windows 7 or Windows 8 (when it is available)
What would you do in my case?
