Have wifi connection can not connect though lan
billros
Can not connect my computer to the Internet code651 my work works fine ( xboxs ps3 kindles phones) can anyone help
tomtatsfield
4
Hi had a similar problem, this worked for me check if traffic is showing under local area connection status if so then disconnect from lan run troubleshooter and connection is back.
Good luck
Tom
