T Racks authorization problem
Last response: in Home Audio
Anonymous
October 4, 2004 2:52:41 AM
Archived from groups: rec.audio.pro (More info?)
I finally bought my Mbox, set it up, installed everything: Pro Tools LE,
Sample Tank, Live Reason Adpated and T-Racks, but when I launch the
T-Racks plugin, I am asked for the serial, which I have from the site,
but it's not being accepted.
Any suggestions? I can't see to find anything on the website regarding
this problem
My setup:
iBook G4 800
640 Megs Ram
30 G HD
MBox
utilizing an external HD for files.
Thank you
KelL
AFTRA
"Religion is the most malevolent of all mind viruses."
--Sir Arthur C. Clarke
Anonymous
October 4, 2004 7:04:48 AM
In article <HailEris-FCAA5C.22524103102004@individual.net>,
> this problem
You're probably typing a 1 (one) instead of an l (ell) or possibly an o
(oh) for a 0 (zero). If it's possible, try cutting and pasting the
response codes instead of retyping them.
What a pain in the rear...
Best of luck,
Monte McGuire
monte.mcguire@verizon.net
Anonymous
October 4, 2004 7:04:49 AM
In article <monte.mcguire-279B0B.23044803102004@news.verizon.net>,
Monte McGuire <monte.mcguire@verizon.net> wrote:
!In article <HailEris-FCAA5C.22524103102004@individual.net>,
! KelL <HailEris@mailcity.com> wrote:
!> I finally bought my Mbox, set it up, installed everything: Pro Tools LE,
!> Sample Tank, Live Reason Adpated and T-Racks, but when I launch the
!> T-Racks plugin, I am asked for the serial, which I have from the site,
!> but it's not being accepted.
!> Any suggestions? I can't see to find anything on the website regarding
!> this problem
!You're probably typing a 1 (one) instead of an l (ell) or possibly an o
!(oh) for a 0 (zero). If it's possible, try cutting and pasting the
!response codes instead of retyping them.
I have been copy/pasting. It's not letting me PASTE (or enter any info
for that matter).
!What a pain in the rear...
Tell me.
!Best of luck,
Thanks.
!Monte McGuire
!monte.mcguire@verizon.net
KelL
AFTRA
Anonymous
October 4, 2004 8:04:05 PM
> for that matter).
Lots of authorization boxes are that way, for obvious reasons. When I've
met such troubles it has always turned out to be that I was misreading a
letter for a number or the opposite, or that the caps key was supposed
to be on, or off, etc.
It pisses me off that software vendors, after taking a few hundred bucks
from my wallet, can't be bothered to just _tell_ me what is the protocol
for successfully engaging the right to use their product.
ha
