Sign-in / Sign-up
Help With Wireless
  • Configuration
  • Wireless
  • Gateway
  • Windows XP
  • Wireless Networking
Last response: in Wireless Networking
September 14, 2012 11:18:18 PM
I have a gateway laptop. I just put windows XP on it. It was working good. I have a Cisco AE2500 to get the wireless to work. Was working good but now stopped working on the wireless. The window pops up and says I have wireless networks in range but now I can't see any of them when I click on the box. Also has a red X on the wireless box. Was working great the other day, Computer works fine when hooked up with a LAN. I have tried to reinstall the adapter and it says i is ok. Could the USP Port be bad?
More about : wireless
a c 94 F Wireless
September 14, 2012 11:58:12 PM
sounds like you turned off your wireless. Is there a switch and/or Fn+ Function Key
m
l
September 15, 2012 12:19:16 AM
I have not found a switch. I think I may have did something like that also. I am not sure how to get it back on. Been messing with it for three days now.
m
l
