Help! My laptop never used to have issues with connecting to routers. But ever since we replaced the router, my laptop can no longer connect to the wireless. My brother's laptop can still connect to the wireless. Although my laptop cannot detect my wireless, it is able to detect my neighbour's wireless.
Also tried connecting LAN cable to my laptop to the router, I am unable to get internet access as well. I tried repair, fixing the internet connection but my laptop is unable to fix it. im running on windows vista x32 and a d-link router 192.168.0.1 . here is a snapshot of the cmd/ipconfig/all page from my brother's laptop that can connect to the wireless connection at home:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
Windows IP Configuration
Host Name . . . . . . . . . . . . : User-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5B125 Wireless Network Adapter
Physical Address. . . . . . . . . : 44-6D-57-1E-1D-8A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::a477:f214:6173:ef3f%12(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.18(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Saturday, September 15, 2012 12:52:35 PM
Lease Expires . . . . . . . . . . : Saturday, September 15, 2012 3:22:45 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 390360407
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-D8-CA-69-04-7D-7B-9A-07-08
DNS Servers . . . . . . . . . . . : 202.156.1.16
218.186.2.16
218.186.2.6
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Atheros AR8151 PCI-E Gigabit Ethernet Con
troller (NDIS 6.20)
Physical Address. . . . . . . . . : 04-7D-7B-9A-07-08
Tunnel adapter isatap.{5ADFB598-8E28-4B77-BF1D-6C47B3CD79C9}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.{33509B41-60EB-41BC-A570-7778E7277B95}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:244c:257c:3f57:ffed(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::244c:257c:3f57:ffed%13(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
The ipcong/all details on MY laptop which would not connect is:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\adminNUS>ipconfig/all
Host Name . . . . . . . . . . . . : u0708341
Node Type . . . . . . . . . . . . : Mixed
Description . . . . . . . . . . . : Intel(R) 82566MM Gigabit Network Connecti
on
Physical Address. . . . . . . . . : 00-15-58-84-AE-77
Wireless LAN adapter Wireless Network Connection 2:
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Con
nection #2
Physical Address. . . . . . . . . : 00-1B-77-7C-91-5B
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 00-19-7E-F7-21-27
Tunnel adapter Local Area Connection* 7:
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #3
I logged onto 192.168.0.1 and these are the details I got of my router:
Network Configuration
LAN
IP Address: . . .
MAC Address 00:24:01:de:ad:05
WAN
IP Address: 116.89.115.2
MAC Address: 00:26:5a:56:a3:bf
Duration D: 00 H: 04 M: 00 S: 00
Expires: Sat Sep 15 17:42:56 2012
IPv4 DNS Servers: 202.156.1.16
218.186.2.16
218.186.2.6
if anyone has a clue on how i should troubleshoot this i would really appreciate it! thank you!!!
Sorry i'm like a tech retard so if you have any ideas, could you provide detailed steps to troubleshoot this thank you!!!!
Another update: I tried importing the network settings from my brother's laptop using a USB key but it did not work. I imported the network settings to my laptop and it told me that the wizard could not create the wireless connection. However, it shows up if I click under "manage wireless networks" however.
218.186.2.16
218.186.2.6
troller (NDIS 6.20)
erred)
on
nection #2
LAN
IP Address: . . .
WAN
218.186.2.16
218.186.2.6
