HS801 V600 problems
Archived from groups: alt.cellular.motorola,uk.telecom.mobile (More info?)
Hello all,
I've just got a V600 with a free HS801 headset. It's not been easy going
with the headset.
I have paired the device and it works nominally, but the buttons on the
headset do not respond in remotely the same way as they are supposed to
according to the manual. Even turning it on and off is a hit and miss
affair, sometimes when pressing both buttons the headset will turn on/off,
other times it just ignores me.
I also have voice dialling enabled, but pressing the button on the headset
to activate it does not work, it merely dials the last called number after a
random pause! Very annoying.
There was a brief moment when it seemed to be working perfectly, but it came
and went for no apparent reason, and now it's back to ignoring me.
It works so long as I do everything with the phone, and ignore the buttons
on the headset.
Has anyone any ideas?
Also which of the two modes headset/handfree does the v600 use, and how can
I differentiate between the two?
This may be the cause of the problem.
3 answers Last reply
More about hs801 v600 problems
  1. Archived from groups: alt.cellular.motorola,uk.telecom.mobile (More info?)
    "JF" <me@memail.com> wrote in message
    news:Lihcd.2302$0p.451@newsfe6-win.ntli.net...
    > Hello all,
    > with the headset.
    The HS801?? Far as I know there are only two bluetooth headsets from
    Motorola, the 810 and the 820. The 810 turns off and on by folding and
    unfolding the mic boom. The volume buttons are used individually for
    controlling volume and if you press them together while talking on the
    headset it turns off the blue status light for the duration of that phone
    call.
    > a random pause! Very annoying.
    Since I'm a V710 ower, I'm not at all familiar with how it should work on a
    V600, but I assume it would be much the same. I know if I don't have 'voice
    dialing' enabled in the headset menu, the button on the headset won't do
    anything if I push it. So check that out and maybe you have it set wrong?
    > came and went for no apparent reason, and now it's back to ignoring me.
    > on the headset.
    Could be a bad headset perhaps?
    God Bless America!
    Bob the Printer
    Our web pages are located at:
    http://mywebpages.comcast.net/bdolson/
    Now with a picture link to the webcam near
    Mount St. Helens volcano!
    Or you can click on the link below to go to the
    the Mt. St. Helens page.
    http://www.fs.fed.us/gpnf/volcanocams/msh/
    Please note that if it's nighttime there you
    will see nothing but 'hash' in the picture.
  2. Archived from groups: alt.cellular.motorola,uk.telecom.mobile (More info?)
    "Bob the Printer" <bdolson@comcast.net> wrote in message
    news:b-mdnU3woP2KSOzcRVn-tg@comcast.com...
    >> Hello all,
    >> with the headset.
    >> on/off, other times it just ignores me.
    > call.
    >> headset to activate it does not work, it merely dials the last called
    >> number after a random pause! Very annoying.
    > a V600, but I assume it would be much the same. I know if I don't have
    > 'voice dialing' enabled in the headset menu, the button on the headset
    > won't do anything if I push it. So check that out and maybe you have it
    > set wrong?
    >> buttons on the headset.
    > God Bless America!
    > Bob the Printer
    I also have a V600 that was bundled with a HS801 headset. I agree with the
    OP, the HS801 seems to not do all it's supposed to do! Switching on/off
    seems to require a very prolonged simulateous 'double' button press and I
    have yet to make the volume controls make any difference to the, err...
    volume.
    I never make calls via the headset - I only use it for incoming calls while
    driving.
    Maybe we now know why they give 'em away free!
    Simon H
  3. Archived from groups: alt.cellular.motorola,uk.telecom.mobile (More info?)
    "Simon H" <simonh@deadmailbox.com> wrote in message
    news:cktdsl$m0b$1@hercules.btinternet.com...
    >>> Hello all,
    >>> with the headset.
    >> call.
    >> set wrong?
    >> God Bless America!
    >> Bob the Printer
    > volume.
    > while driving.
    > Simon H
    I use the headset that was bundled with my v600 with no problem Once I
    worked out the difference between a press and a brief press.
    A brief press lets you voice dial a press dials the last no
Motorola Mobile Gaming Headsets
