Tom's Hardware > Forum > CPU & Components > Sound Cards > help! can this be a soundcard problem??
Forum CPU & Components : Sound Cards - help! can this be a soundcard problem??
recently bought a new asus a7v333, after having burned my last mobo, cpu (t-bird 950) stayed in tact tho :) phew
BUT there is a problem!!
the system is VERY unstable. now i've tried all sorts of cpu/memory/3d benchmarks in endless loops, NEVER crashed, it only crashes in games, internet-radio (and realplayer/wmp for that manner), hence, only crashes when there is sound.
now, i CAN hear mp3's in winamp, and games do work until a certain point, it doesnt ALWAYS crash when sound comes in, but whenever it crashes, a sound is playing.
so im wondering if this is a problem with the onboard sound on the a7v333, as i dont use a pci/usb soundcard... i use the onboard one.
any1 else ever had a problem like this that turned out to be a sound card? or turned out to be something else?
PLEASE help! :) thanks for any replies.
<font color=red><pre>screw you guys ----->>> im going home</b></pre><p>
Sponsored Links
also, the recording volume is really really low
Reply to yableez
i dont think i can help but you might want to put down what
kind of system you got.
CPU
Chip set
Sound card
Graphic card
OS
mine crashes big time too. Really nothing can do about it
because in my case it seemed to be a driver problem
(audigy + VIA chip set + windows XP = high pich tone crash)
http://www.geocities.co.jp/College [...] index.html
Korea....good sport?
Reply to silly_rabbit
I am Johnny Wishbone, psychic extraordinare from the Island of St. Croix. Wait! It's coming to me. It's getting clearer... Mmm... Mmm... It pop into my head! He has a SB Live!
To start press any key. Where's the "any" key? --Homer Simpson.
Reply to Black_Cat
Hmm, OK, sounds like a hardware issue with the onboard sound and the VIA chipset. Officially these don't exist, so I can't tell you any more specifically on that.
What I can tell you is that many companies fix hardware problems with software, so you might investigate newer drivers or BIOS.
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
Reply to Crashman
Johnny Wishbone Eh! Pretty snappy there Black Cat. Ryan
Details, Details, Its all in the Details, If you need help, Don't leave out the Details.
Reply to 4ryan6
Your Sigs not going to get you much real help. Ryan
Reply to 4ryan6
well just found out that it wasnt the soundcard, cause' i disabled it an still crashed
it cant be a bug between the soundcard and the via kt333 cause they are onboard! asus wouldnt have released a board that has problems with itSELF lol
Reply to yableez
Yeah. It's too bad I read at a 3rd grade level. The original post clearly states he's using onboard sound. Duh. I was a bit too eager to take another poke at Creative. :smile:
Reply to Black_Cat
I just installed a Blaster Live 5.1 using the latest online drivers. No problems. Sound is just fine with the 25 games on my harddrive.
I want to die like my Grandfather...in my sleep...not screaming in terror like his passengers.
Reply to Kronos
There are 1195 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
