Motorola V600 - Disable ring-style buttons on side of phone
Archived from groups: alt.cellular.motorola (More info?)
With a V600 is it possible to prevent the ring-style changing when the
buttons are accidentally pressed on the side of the phone. This is really
annoying me as the ring-style often changes from loud to silent or vibrate
when the phone's in my pocket!
Ben
5 answers Last reply
More about motorola v600 disable ring style buttons side phone
  1. Archived from groups: alt.cellular.motorola (More info?)
    yes, just use the lock application feature on your ringstyles menu, or seem
    edit your 0032_0001 seem to enable the classic and always useful menu * lock
    keypad function.
    "bengy" <ben.fidge@nospam_btopenworld.com> wrote in message
    news:417ba7ad$0$43613$ed2e19e4@ptn-nntp-reader04.plus.net...
    > Ben
  2. Archived from groups: alt.cellular.motorola (More info?)
    But doesn't that lock all of the keys?
    "Anybody" <nomailover@rogers.com> wrote in message
    news:E8GdnfBbFLEQVebcRVn-uA@rogers.com...
    > seem
    > lock
    > keypad function.
    >> vibrate
    >> Ben
  3. Archived from groups: alt.cellular.motorola (More info?)
    The Menu *? Yes, you would have to hit Menu * before using the cell, but
    not to answer a call
    "Attilia the Hun" <slbarrus@cs.com> wrote in message
    news:veQed.17913$%t3.5354@lakeread01...
    > > seem
    > > lock
    > > keypad function.
    really
    > >> vibrate
    > >> Ben
  4. Archived from groups: alt.cellular.motorola (More info?)
    Not sure about V600 but V300 works as follows. Probably same for
    yours. Menu\Settings\Security\Lock Application\ *****Now enter
    your unlock code****** \Ring Styles *change it to locked* and
    there you go. Ring styles are locked out. You have to enter the
    unlock code to changed them. You can change to vibrate mode by
    repeatedly pressing volume down while the flip is open. It will ask
    for unlock code, just ignore it. Change it back by repeately
    pressing volume up key until it's back to the volume level you prefer.
    On Thu, 28 Oct 2004 03:11:07 -0400, "Anybody" <nomailover@rogers.com>
    >> > seem
    >> > lock
    >> > keypad function.
    >really
    >> >> vibrate
    >> >> Ben
  5. Archived from groups: alt.cellular.motorola (More info?)
    Some users seems to use the security feature (protections on
    applications) of this phone to protect/restrict the ring-style changing.
    Don't know if it works. Let us know !
    > Ben
Motorola Phones Style
