Power Supplies: ATX vs PS/2
BKraengel
14
Good Afternoon,
Anybody know where I can find some basic power supply data? The Intel P4 ATX Mobo spec calls for an ATX-type P/S. The ATX case I like is furnished with a P4-ready PS/2-type P/S. What's the difference? Are thay dimensionally the same; can I simply replace the PS/2 with an ATX?
Bill Kraengel
PS/2 as opposed to something larger or smaller. I have no idea why they don't simply READ THE LABEL which usually says ATX 2.1 or ATX 2.2.
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
PS/2 refers to the physical dimensions of the PSU compared to the Full AT size PSU's (big, had an L shaped cut out in one corner).
ATX utilizes the PS/2 size and changed the electrical specifications (and initially fan position if memory serves).
AntecRep
