News
CES 2007: Harman Kardon announces GPS/PMP combo
Harman Kardon, mainly known for its speaker systems, is entering the GPS navigation market with a portable device that can also play music and videos. The GPS-500 is PlaysForSure-compatible and is small enough to fit in the palm of your hand. Read more
Latest Reviews & Articles
Overclocking Core 2 Duo: Power Versus Performance
Intel's fastest Core 2 Duo, the E8600, runs at 3.33 GHz. But if you're a performance-hungry power user, we found that you can actually increase the chip's efficiency by overclocking it, thanks to 45 nm manufacturing and plenty of built-in headroom. Read more
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
All the Reviews & Articles
Tom's Hardware > Forum > Audio > Pro Audio > HELP using Harman/Kardon CDR 20 CD burner
Archived from groups: rec.audio.pro (More info?)
Ok, So Im a newbee to these units.
I HOPE someone has one and can help.
Im trying to record from a tape deck.
I come out of the deck (out/play) and into the CDR In.
then on deck 2 of the cd unit I choose analog.
I put a blank cd in.
Ok, so then I hit play on the tape deck and get nothing. the audio is
coming out of the deck because I bypassed the rca cables past the cd.
I hit record on the cd and it says NO AUDIO.
Any idea whats wrong? I cant be hooking somthing up wrong, can I???
PLEASE let me know if someone can help.
Thank you again group.
Sponsored Links
vsnsound@aol.com (Jay) wrote in message news:<94c5d9af.0410071620.6c16fd89@posting.google.com>...
Is your blank disc a DATA CD-R or a MUSIC CD-R.
The CD recorder might be complaining becuase consumer CD recorders require
MUSIC CD-Rs thanks to the RIAA.
Mark
Reply to mark
- 0 +
Thanks for the reply.
Im using Imation CD-R.
It says on it Compact Disk Recordable on it. They arent generic or cheep disks.
PLEASE let me know what anyone thinks.
Jay
> Mark
Reply to jay
But does it say Audio anywhere? - if not then you'll need to buy some
Audio CD-R's.
Imation don't make their own CD's either - they just rebrand other
people's and they don't always use the best discs.
Cheers.
James.
Reply to Anonymous
In article <94c5d9af.0410191703.742bfdfb@posting.google.com> vsnsound@aol.com writes:
> disks.
If your recorder is one that requires audio blanks (and I suspect that
it is) the standard computer store blanks won't work. The audio blanks
have a pre-recorded track that the recorder looks for. However I would
expect that it wouldn't let you get far enough to try, but would
simply tell you that it wasn't a recordable blank and spit it out.
Does the manual say anything about this?
There are only a few companies that actually make recordable CD blanks
(and I-Mation isn't one of them). All the name brands buy blanks from
one of the few makers, and, given where they're sold and for what
application, they buy from the cheapest source, and may very well
change sources every few months to get the best price. So what appears
to be the same make and type of blank that you buy today that you
bought a few months ago (and which worked) may not work now.
You really just have to experiment, buy from a local dealer, and not
be afraid to return the package of blanks if you try a few and they
don't work. I've never had a problem returning an opened pack of CD-Rs
to Best Buy or Micro Center. Comp USA is a bit fussier about returns
so I don't buy anything there that I expect that I might not want to
keep.
It might be worth calling a real media supplier, telling them what
machine you have, and ask them if they know what blanks work well in
it. They may be willing to send you a couple of samples. Don't be
afraid to ask. Media Supply and Cassette House (the obvious web sites)
are friendly folks who sell enough product to have a good sense of
what works, or is likely to work, with what.
I'm really Mike Rivers (mrivers@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Reply to Anonymous
There are 732 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
