Printer installation problem on Win7
Hi,
I have installed windows7 on Dell Latitude D630 Laptop. I am not able to install Printer on it. When press Add Printer it is not showing any USB port, although i can use these ports for net and for Pen drive. Plz suggest what to do.
1 answer Last reply
More about printer installation problem win7
  1. what kind of printer?
    with HP for example you run the installation software which then will ask you to plug in the printer when the software is ready to install the USB drivers.
Latitude Windows 7 Printers Laptops
