Equipment for a home studio/PA and hifi center
Last response: in Home Audio
Anonymous
October 11, 2004 6:18:01 PM
Archived from groups: alt.music.home-studio,rec.audio.pro,rec.audio.opinion (More info?)
The purpose of my equipment is three fold.
1. Home hi fi (I want it to sound louder and better than my desktop
Sony). Noise free to my ears and good speakers.
2. As a "home PA". I sing and play my acoustic/electric through it.
3. As a "studio monitor" when I add a recording outfit to it.
This is my first venture into PA gear and I want to use it to play my
CD collection as well. I have not purchased equipment yet but this is
what I am thinking. I put the Musicians Friend number so you can look
at specs, but I don't care where I buy the stuff, though I like their
45 day return policy.
1. Alesis RS300 Reference Series power amp. Musicians friend #485525
(90 watts into 8 ohms per channel, no fan)
2. Behringer Eurorack UB1222FX-PRO mixer (also serves a preamp for CD
player) MF #631229
3. Sony RCD-W500C CD recorder/player MF #244679
4. Speakers. I need two 8 ohm, non-powered, near field 100 watt
speakers that will sound as good as possible with this equipment. I am
thinking something like Behringer Truths, but non-powered. I am
stumped on this one. Any suggestions? An important choice. Something
with a silk dome tweeter? I think NOT a horn? Something designed for a
studio monitor, near field or maybe medium field. Room is 20 x 30, 8'
ceiling to 16' ceiling sheetrock walls carpet floor.
My other quandry is I do not know how a sub-woofer would fit into
this. If I get a sub do I just plug it into an output of the mixer?
I currently have a mic and mic stand and that's about it. Right now I
play my acoustic electric through an acoustic amp, I have a small Sony
desktop hi fi ($400 model) and a Zoom home 4 channel solid state
recorder.
I will be adding a home recording system some day, and I may want to
use some of this stuff down at the gig someday (that is if I ever do
get any gigs). And maybe adding mike pre-amps, voice effect boxes,
more microphones etc.
Anyway, that is my mission. I would appreciate any suggestions. Yes I
can spend more, but this is the sort of range I think I can buy and
learn with and should get ok sound.
acoustic/electric guitar-------|Mixer|--------|Amp|l--------Speaker
microphone---------------------| | | |r--------Speaker
CD player----------------------| | -----
I'd appreciate any constructive help.
Anonymous
October 11, 2004 9:21:54 PM
"Doug" <anothername@access4less.net> wrote in message
news:1b3f4ae6.0410111318.9cfc177@posting.google.com
There are non-powered versions of the Truths. Same model numbers as the
powered ones, only suffix with a P for passive.
Price difference is about $100 a pair, suggesting that using a separate
power amp is the costlier way to go. Conventional wisdom is that the powered
versions have the potential to sound better than what you'd get with a
separate power amp because the built-in amps are optimized for the speakers.
Anonymous
October 12, 2004 1:43:42 AM
How does volume control work with the active speakers. What do you do,
just turn the speakers all the way up and control the volume with the
mixer?
"Arny Krueger" <arnyk@hotpop.com> wrote in message news:<ycidneinC9L6ZPfcRVn-oA@comcast.com>...
Anonymous
October 12, 2004 4:25:20 AM
No, Alesis does not make good amps. Look into Hafler, go used to save coin,
they've always been good value.
> player) MF #631229
A suitable mixer for basic PA use, a rough start for recording.
Any CD recorder is a bad choice - nothing special for sound quality, no
editing capabilities, and it requires expensive audio-only media, unless you
spend about $800 on a pro model. Get into a PC-based DAW even if you just
use on-board sound i/o at first.
If you get entry-level studio monitors get powered ones. They typically use
4 Ohm or even 2 Ohm drivers and work best with matching amps. Behringer
Truths use 4 Ohm woofers and tweeters. Other amps will work, but no better
than optional built-in amps unless you spend a fair bit. Either way they
won't be adequate for PA.
> I am
You're kind of screwed here. You'll need horns to get adequate PA power for
that room, but they certainly won't be studio reference quality. Very few
metallic domes sound decent, cloth/silk ones generally sound best.
You'll be hard-pressed to get adequate PA power to that amount of airspace
with anything approaching studio caliber precision for under $2k.
You should read a lot more into subwoofers before buying one, it's easy to
do more harm than good.
If I were you I'd get something like the Truths for entry-level nearfield
monitoring and hi-fi use, and also a pair of powered PA speakers for PA and
higher volume hi-fi.
You're going to need to treat that room too.
Anonymous
October 12, 2004 1:54:39 PM
On 11 Oct 2004 21:43:42 -0700, anothername@access4less.net (Doug)
>mixer?
Just like it does with any mixer and power amp. The only difference
being the power amp is split in two and is somewhere else.
CubaseFAQ www.laurencepayne.co.uk/CubaseFAQ.htm
"Possibly the world's least impressive web site": George Perfect
Anonymous
October 12, 2004 10:17:53 PM
So does that mean I have to change the volume of the speakers when I
want to change volume. Or can I control the volume from the mixer
only?
Laurence Payne <l@laurenceDELETEpayne.freeserve.co.uk> wrote in message news:<7s6nm05na3g717ob2tsg4h44hkagjo3fot@4ax.com>...
> >mixer?
Anonymous
October 12, 2004 11:32:22 PM
news:1b3f4ae6.0410121717.5f894486@posting.google.com...
> only?
Either way works. I keep my monitors at a constant level and use audio
card's mixer to control the volume. It works fine for me.
A: Because it messes up the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing on usenet and in e-mail?
Anonymous
October 13, 2004 2:52:39 AM
>only?
If your mixer has a monitor section with a volume control for the control
room outputs, some routing for the control room outputs so you can listen
to various busses in mono or stereo, then you are good to go.
If you do not have a monitor section and no seperate control room outputs,
you can buy any one of a number of outboard boxes which basically emulate
the monitor section of a console. Coleman Audio makes a nice one. For
the most part these don't handle PFL or aux solos as nicely as a real monitor
section, though.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
Anonymous
October 13, 2004 2:18:15 PM
On 12 Oct 2004 18:17:53 -0700, anothername@access4less.net (Doug)
>only?
I repeat - it's just like any other mixer and power amp. Send a
signal from your mixer peaking at whatever level you intend to call
maximum. If the sound is painfully loud, turn the power amp controls
down a bit. If it's not loud enough when full up, buy bigger
speakers. Once this is set appropriately, leave it alone and mix
with the mixer.
Anonymous
October 13, 2004 2:18:16 PM
Well my concern is that it is a bit of a hassle to go to each powered
speaker and change the volume, then tweek the mixer. I want volume
controls within reach of my hand at the mixer, I don't want to have to
make a trip to the powered speakers. Thus my concern. As for what type
of mixer, it is a Behringer UB1222FX-PRO, but could be some other one
if it will work better (I haven't bought it yet).
If an Alesis power amp is not a good one, can anyone clue me in on a
100 watt power amp that has no fan and IS a good one?
Laurence Payne <l@laurenceDELETEpayne.freeserve.co.uk> wrote in message news:<0cspm0la0gc7cf7trl3dff2cntgainmuq4@4ax.com>...
> >only?
> with the mixer.
Anonymous
October 13, 2004 2:21:29 PM
On Tue, 12 Oct 2004 19:32:22 -0700, "Jim Carr" <jim@azwebpages.com>
>> only?
Are we talking about an actual mixing board, or a software mixer in
the computer? Same answer, really. The source needs to be set up
with optimum gain structure. The final part of this structure is
setting appropriate amp. levels.
Anonymous
October 13, 2004 9:50:23 PM
>A: Top-posting.
This is so great.......stored it for future use.
Sander deWaal
"SOA of a KT88? Sufficient."
Anonymous
October 13, 2004 9:50:24 PM
"Sander deWaal" <nospam@wanadoo.nl> wrote in message
news:gkjqm0d20ao51ju0qdkuln4m1hrvg5gqrs@4ax.com...
> >A: Top-posting.
I take no credit for it. I saw it and saved it myself!
Anonymous
October 13, 2004 10:25:45 PM
Yes, building larger or smaller enclosures is the only way to change their
volume.
TonyP.
