Hey ppl,
i'm having a bit of a scumbag hacking problem!
Had a Netgear wireless router sitting there for years with little or no maintenance done to its security - had WPA2-PSK set but with a relatively weak password - and i decided to attend to it back in April. So, i changed the admin password and the wireless password and tinkered with a couple of basic settings. Went back a few days later and i couldn't access it using the new password. So, i figured hey, that's not on...some thieving git must have been leeching my internet for years and decided, when i took back a little control, to take over the admin rights of my router!!
Anyways, i reset it, changed the SSID, changed the ip, stopped broadcasting and set up much stronger passwords (there wasn't much else i could do with this dated router, i think)
It seemed to be working ok until the possible DOS attacks(?) started getting more and more frequent and unexplained fluctuating speed rates.
So, i updated my router to a TP-Link about a month ago and initiated all the security feature bells-and-whistles i possibly could. Everything seemed to be working peachy until tonight. The wireless suddenly cut off, so i tried to connect with ethernet...and no joy! No ping response...it simply ignored both my laptops and my phone.
My question is this: How can i be certain it's one of 3 possible neighbours raping my router and not some random, devious hacker over the internet
Security implemented:
- strong passwords
- mac filtering
- alternate router ip
- SPI firewall
- DOS protection
- ICMP-Flood attack filtering
- UDP-Flood filtering
- TCP-SYN-Flood attack filtering
- Ignore ping packet from WAN port
- Forbid ping packet from LAN port
- strong passwords
- mac filtering
- SPI firewall
- DOS protection
