N nhoward77 Honorable Nov 5, 2012 3 0 10,510 Nov 6, 2012 #1 How do I best add one or two additional wireless output ports to a fully used four port wired router?
PhilFrisbie Splendid Apr 22, 2006 6,472 3 26,465 Nov 6, 2012 Solution #2 Replace the router with a wifi enabled router. Upvote 0 Downvote Solution
N nhoward77 Honorable Nov 5, 2012 3 0 10,510 Nov 13, 2012 #3 Best answer selected by nhoward77. Upvote 0 Downvote
N nhoward77 Honorable Nov 5, 2012 3 0 10,510 Nov 13, 2012 #4 PhilFrisbie : Replace the router with a wifi enabled router. Thank You very much for your answer. nhoward77 Upvote 0 Downvote
